Author Topic: Harley rear wheel  (Read 737 times)
Offline tgtint
Harley rear wheel
« on: May 24, 2010, 06:09:07 PM »
So my project has a "hog" rear wheel, 16" Harley rear wheel laced onto the stock drum I'm guessing?  Just curious about the history behind this, not sure there are any benefits to it other than if you like that look.
Not sure I'm sold on it but I want to try and make it work.  How easy is it to fit other wheels to these bikes?
Sorry if this is a redundant question, bikes are new to me and I'm dying to learn more fast.  I'm reading threads here like a madman.
1973 CB750
Re: Harley rear wheel
« Reply #1 on: May 24, 2010, 06:27:43 PM »
The "Harley" style rear wheel conversion was a period modification done for looks, marginally lowering the bike's rear, drop the fork legs and lower it front and rear, if that's an issue. You could run less pressure for a softer ride, especially for those putting struts on in place of shocks. Yes people do that.
Also, the bike came with a 4.00x18 tire which wore out pretty fast. I think the "Hog" rubber lasted a bit longer, or it was thought it might.
Some current bike builders put them on cafe racers, but I can't fathom why. I'm not convinced its any type of a performance upgrade and that's what cafe racers is all about. The 16" wheel is heavier, squirmier, and just doesn't fit in my mind. But to each their own.
You can easily lace a 17" (which was stock in 1978+/-) or an 18" rim and restore the original look. Use a bit wider rim for a more modern, wider tire. But between the rim, spoke kit and tire, you'll likely have $400 in the conversion. Could probably sell the 16" rim and spokes for $50 to $100.
Its not any kind of a safety issue, so keep it and run it if you have other things to do. I think there is a wider selection of 16" tires these days then back then, different profiles and tread patterns.
Offline tgtint
« Reply #2 on: May 24, 2010, 06:31:01 PM »
I'd like to keep it and make it work, crazy as it sounds this bike was done up in the early 70's and I want to change as little as possible on the looks side so long as it doesnt hurt looks/safety.
what about front wheels, I'm thinking more beef up front might help balance it out.
1973 CB750
« Reply #3 on: May 24, 2010, 06:35:52 PM »
Understood about the rear rim. As I said it was a popular "period" conversion, the shop i worked in sold a ton of them.
Wheels or tires? Can't really change the wheel much as it would look weird under the fender.
The stock rim in front will carry a 110/90x19 tire which is a lot of rubber. The steering will feel heavier, but its what i ran with for decades.
Still not as much as the 16" but there is a room limitation with the brakes and fender.
