Author Topic: '77 550 blinker noise.  (Read 6136 times)
Offline le_sterls
  • Comic book
  • Well than...
« on: May 25, 2010, 12:01:05 PM »
I ride a '77 cb550k, and it has a hideous beeping noise when I put on the turn signals. I've located the speaker, but don't know if it'd be wise to remove, as it may cause a short. Do you fellas' just put up with the noise? or is there something I can do about this? It greatly over powers the sound of the engine, and I can hear it clear as day in a full face helmet. Any suggestions would be appreciated.
le_sterls
That's what I'd like to hear.
'77 CB550k - running... For now...
scrapvalue
Re: '77 550 blinker noise.
« Reply #1 on: May 25, 2010, 02:38:08 PM »
Shouldn't be any problem with unhooking it.
I know a couple people who removed them off their CB750's.
« Reply #2 on: May 25, 2010, 02:52:52 PM »
i removed mine with no trouble .. it plugs in either inside the headlight or (if your lucky) just behind the headlight
Offline lone*X
« Reply #3 on: May 25, 2010, 06:16:10 PM »
The blinker beeper does serve a purpose you know.  It is not there just as a nuisance.  Our bikes have non-canceling signals.  A blinker you forget to cancel after a turn is sending a message to all those cars and trucks around you that could spell trouble when they pull in front of you thinking you were going to turn the other way.  At the minimum riding down the road with a turn signal blinking just makes the rider look stupid.   Obviously the beeper is not a requirement, just want you to think about why it was put there by the engineers.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: May 25, 2010, 06:37:25 PM »
I've performed a beeperectomy on my '77 550 without mechanical or electrical issues.  As Lone quite correctly points out, you do run the risk of pulling a geezer by not canceling the signal when you complete your turn.  I have to admit, I've done it many times!  But you eventually get into the habit of canceling the signal yourself.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Nikkisixx
« Reply #5 on: May 25, 2010, 07:00:23 PM »
Le_Sterls I can't believe yours is still hooked up!   Also, I can't believe you guys can hear that darn thing when you are riding.  It usually only makes enough noise to be annoying while sitting at a light.   ;)
Offline BlindJoe
« Reply #6 on: May 25, 2010, 07:05:03 PM »
hack those sob's off, it'll keep you on your toes
Offline fatmatt650
  • Part Deux
« Reply #7 on: May 25, 2010, 07:07:46 PM »
Mine blinks at different rates w/ different speeds. Is it supposed to do that? Also my rear turn signals do not function as running lights. I want to think that's just how it is from the factory but have no idea. 1976 cb750f.
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #8 on: May 25, 2010, 07:22:01 PM »
My 78 750k's rear lights are 1 wire each are your's two?  Do your signals blink slow below 2700 - 3000 and drastically faster above that?  I don't think the charging system really functions below that rpm
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
Offline my78k
« Reply #9 on: May 25, 2010, 07:23:10 PM »
rears don't generally operate as running lights...just the fronts.
As for the blinker speed changing it could be a sign that your relay is failing or that your charging system may be out of whack or that you have incorrect wattage bulbs. Usually the easiest fix is to convert to an electronic flasher relay (3 prong).
Dennis
Offline lone*X
« Reply #10 on: May 25, 2010, 07:57:47 PM »
Just a little something extra to throw in.  My VTX 1800 also came with non-canceling signals.   Several years ago on the VTXOA board I found a reference to http://www.blinkerbuddy.com/ , spent a few bucks and am totally happy with the product.  You never forget to turn the signals off.
Lone*X  ( Don )
75 CB550K1
Offline my78k
« Reply #11 on: May 25, 2010, 08:14:13 PM »
it's funny, I have never had a bike with self cancelling signals but am anal about turning them off. My buddys that I ride with get annoyed with me making hand gestures to them off when I am behind them (in their mirrors) trying to get their atttention to turn them off.
« Reply #12 on: May 25, 2010, 08:19:38 PM »
Neat device!  and a GREAT way to get the ladies on ur bike!!  ;)
Sure.
Is it hard?
Offline jro75
« Reply #13 on: May 25, 2010, 08:25:02 PM »
I was going to disconnect mine but I first tried putting some tape over the speaker and it is now much less annoying.....think I will keep it.
'75 500T
'78 550K
Offline my78k
« Reply #14 on: May 25, 2010, 08:28:07 PM »
LMAO!!! My wife may find riding with me MUCH more fun! I can't believe I have never heard of these!
« Reply #15 on: May 26, 2010, 01:12:12 AM »
You can unplug the leads in the headlight bucket to defeat the buzzer.
However, the buzzer is a reminder for you to turn them off, thereby leaving other drivers slightly less confused about your intentions.  And, it also warns pedestrians there is something other than cars to avoid.
Rather funny that people like loud pipes to draw attention to them, but a warning/safety buzzer annoys the rider.  ::)
« Reply #16 on: May 26, 2010, 04:54:55 AM »
You can always connect the beeper to a switch.  Turn it on when you are backing your bike into a parking slot.  ;D
Sure.
Is it hard?
Offline KB02
« Reply #17 on: May 26, 2010, 05:00:12 AM »
Loud Shirts save lives.  ;D ;D ;D
Another thing to consider is that if YOU can hear it, just imagine how many other people can hear it and will know that you are turning.
Granted, I am the worlds biggest hypocrite. I supports all kinds of safety measures and wear full riding gear with reflective strips, but the turn signal buzzers were the first things to come of my SOHC4's.  ::)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline le_sterls
  • Comic book
  • Well than...
« Reply #18 on: May 26, 2010, 06:35:57 AM »
I realize that it is there as a reminder to turn it off. But it is wayyyyyyy to annoying. I have the stock 4-4 exhaust, so pulling into the left turn lane at some what high rpm, it still over powers the engine. I'm going to look for ways dampen the noise, but I may end up just pulling it off.
Offline Popwood
« Reply #19 on: May 26, 2010, 07:20:28 PM »
Yeah, I thought it was silly at first and a tad embarrassing at a stop light, but you do get used to it. You can also back the switch button off a bit and the signals continue to blink but the sound goes away. Sometimes I wonder if people around me think I'm about to back up! :D
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline tortelvis
« Reply #20 on: May 27, 2010, 06:49:45 AM »
Sounds like you need to replace the blinker fluid!  ::)
Offline le_sterls
  • Comic book
  • Well than...
« Reply #21 on: May 27, 2010, 11:28:19 AM »
I feel like everytime I'm at a light, it's all people hear haha. It does remind me of when I worked at a warehouse, the sound of the high-low backing up. It is a helpful device. However they could've toned it down slightly. (By slightly I mean like 15 decibals, haha.) Perhaps you're right though, maybe the beeping is just an indicator that my beeper fluid needs to be changed. hahaha  :D
Offline lone*X
« Reply #22 on: May 27, 2010, 01:14:42 PM »
Since some of you liked the blinker buddy and could think of additional benefits it could provide, you may be interested in its Big Brother.
http://www.dscbikeshop.com/viberider.html
Lone*X  ( Don )
75 CB550K1
Offline xenoscr
  • 1975 Honda CB750 K5
« Reply #23 on: May 27, 2010, 01:24:11 PM »
Am I imagining it or have I read in these forums that some use the buzzer as an indication of their charging systems state... the more lethargic it begins to sound the worse off you are?
XeNoSCR
1975 Honda CB750 K5
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #24 on: May 27, 2010, 02:08:38 PM »
  Some of the earlier models had an "extra " button below the horn button to silence the beeper when you wanted to. Push the button and the beeper goes silent while the turns still work.
 It's fun to play with pedestrians and cagers at a stop lights. Push the button in and then let it beep once and push it back in. They usually look all around for the source of the beep. Do it again and they look even more. I'm easily amused though.
 Purty cool...
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
