Author Topic: Kick bang smoke  (Read 1380 times)
Offline Motoguy23
Kick bang smoke
« on: May 25, 2010, 02:44:59 PM »
I recently got my 72 CB500 all together so I put gas in it.  I kick it like 5 times and produces a louder than usual pop form one cylinder then smoke comes out slowly.  I kick it 5 more times and the same thing happens and every once in awhile i get like a half kick and  it just stops from like compression.  It ran good but had an oil leak so I rebuilt it and now its doing this.  It has a Dyna S ignition if that makes any difference.
All glory to the hypno-toad.
Re: Kick bang smoke
« Reply #1 on: May 25, 2010, 02:57:47 PM »
Sounds like your coils are hooked up in reverse or your 1/4 and 2/3 are mixed up...
Offline Fritz
Re: Kick bang smoke
« Reply #2 on: May 25, 2010, 03:30:33 PM »
Kick bang smoke
reminds me of this:
http://www.absoluteastronomy.com/topics/Chitty_Bang_Bang
 ;D
But, yes: Sounds like ignition order is wrong
1976 CB550F
scrapvalue
Re: Kick bang smoke
« Reply #3 on: May 25, 2010, 04:16:40 PM »
Forgive me for lack of technical terms, but I believe the center part of the points electronic ignition can be installed 180 degrees off and cause what you are experiencing. It happened to me when I installed my electronic ignition the first time.
It has been a couple of years since the experience.
« Last Edit: May 26, 2010, 01:31:49 PM by scrapvalue »
Offline WFO
  • Will work for powerbands
Re: Kick bang smoke
« Reply #4 on: May 25, 2010, 04:54:18 PM »
+1 that would be my first guess as well.
82 cb650 sc nighthawk - 78 kz 650 b
Offline Motoguy23
Re: Kick bang smoke
« Reply #5 on: May 25, 2010, 04:57:34 PM »
That could be.   I remember now after I had them all off going "Hmmm...  I should have numbered these".  I knew that one coil fired the 1-4 and the other did the 2-3 but I wasn't sure which ones, so I stuck them on there and I guess I forgot that I had no clue which ones when where exactly.
I'm off for a night of partying so I'll have to look into that tomorrow.
Offline Fritz
Re: Kick bang smoke
« Reply #6 on: May 26, 2010, 04:21:06 AM »
The yellow wire is for cyl 2 and 3, the blue one for cyl 1 and 4
1976 CB550F
Offline Motoguy23
Re: Kick bang smoke
« Reply #7 on: May 26, 2010, 12:52:11 PM »
Looked at it today and I hooked the blue to 2-3 and yellow to 1-4  thanks guys.
Offline midnightrider
  • Out of the SOHC4 world for a while...
Re: Kick bang smoke
« Reply #8 on: May 26, 2010, 01:06:59 PM »
I did the same thing, but caught it while setting the static timing. good luck!
1972 CB350 Four - "The Green Hornet"
http://forums.sohc4.net/index.php?topic=84975.0
I love being alive and I will be the best man I possibly can; I will take love wherever I find it and offer it to everyone who will take it... seek knowledge from those wiser and teach those who wish to learn from me.
-- Duane Allman's epitaph
Offline Motoguy23
Re: Kick bang smoke
« Reply #9 on: May 26, 2010, 07:10:42 PM »
switched the wires and how everything is AOK.  Thank you for clearing this up for me.  Sounds great and best part, NO OIL LEAKS!  :D
Offline Jordan
  • What a Long strange trip it's been
Re: Kick bang smoke
« Reply #10 on: May 26, 2010, 07:49:24 PM »
Just for a bit of levity Kick bang smoke sounds exactly like what I have to do each morning in order to wake up, get moving and work out all the aches and pains in places I don't even remember having! except I added loads of coffee to the list.
