Author Topic: Can I re-use a clutch cover gasket?  (Read 2561 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: May 26, 2010, 10:47:41 AM »
Looks fine to me but I've never re-used a gasket before
Offline markb
  • When I finish my current project I might be a
Re: Can I re-use a clutch cover gasket?
« Reply #1 on: May 26, 2010, 10:55:50 AM »
I personally wouldn't reuse any gasket but I guess if you do and it leaks it's an easy one to replace.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline I Zombie
« Reply #2 on: May 26, 2010, 11:58:05 AM »
I've had mine off & on a few times. With no leaks, but I did end up tearin it the last time so a new ones on the way.
78 CB750K
Offline Hush
« Reply #3 on: May 26, 2010, 11:59:29 AM »
Yep I reuse them all the time, just run a fine layer of thin gasket sealer around the casing and the cover before fitting.
Use the kind of gasket sealer that does not go hard though, this helps next time. ;D
« Reply #4 on: May 26, 2010, 12:00:53 PM »
If it comes off clean, its reusable. I usually put the gasket sealer on the cover side only, (or the cases side only) so that I can use them over. But if part of it stuck to the surrendering side, I'd get a new one.
