SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Yep, gauge needle removal...with a twist!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Yep, gauge needle removal...with a twist! (Read 1199 times)
SKTP
Master
on:
May 26, 2010, 10:08:29 PM »
So I'm rebuilding a CB450 K0 speedo/tach. It's going to go on my K8. Yes it might be innaccurate but it will look super sweet. The tach is jammed for some reason so I need to remove it from the face plate. Sounds easy enough. I search and read about the 2 spoons method and expected to pop that needle right off after painstakingly un-crimping the ring. So the question is: is there any reason to belive these needles are not pressed on? I applied a great ammount of force and only managed to slightly warp the center/circle part of the needle. So I stopped. I know this is technically an "other bikes" question, but I thought I might get a quicker reply here and I need to get this thing apart its going to drive me crazy...thanks for any insight
Last Edit: May 26, 2010, 11:36:33 PM by SKTP
Logged
1978k rebuild thread
http://forums.sohc4.net/index.php?topic=68423.0
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
SKTP
Master
Re: Yep, gauge needle removal...with a twist!
Reply #1 on:
May 27, 2010, 02:22:49 PM »
After more searching...I figure I'm just going find something to protect the face-plate then force that needle off...if it bends, I will find a replacement...I'm sure there's no magic way
Logged
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
