Author Topic: rockers side to side play  (Read 578 times)
Offline gmonkey
« on: May 27, 2010, 10:11:59 AM »
Adjusting the valve clearances, I noticed that the rockers have some side to side play.  A few millimeters but definitely noticeable.  Is this normal?  I'm assuming it is but wanted to make sure.
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Re: rockers side to side play
« Reply #1 on: May 27, 2010, 10:57:03 AM »
Normal.
In fact, I use that during adjustment to get the right drag on the gauge.  I little wiggle to get the gauge to release from the gap.
If it won't wiggle, it is too tight.
Offline gmonkey
« Reply #2 on: May 27, 2010, 11:02:33 AM »
Ok, thanks.
On the other hand, I guess I didn't adjust them tight enough.  They slide out without the rocking.  When I tighten down the nut, it actually increases the clearance a bit.  Adjust so it barely moves, tighten down the nut, then the feeler slides around and out freely.
