Author Topic: Engine numbers help  (Read 1125 times)
Offline bobbed_750
Engine numbers help
« on: May 27, 2010, 12:54:20 PM »
Can someone post up a picture of there 76-78 cb750f engine numbers at first look I thought I had got a super sport engine in my new bobber because the engine was stamped "cb750f" but now im not so sure.  If I'm right the super sport engines will have numbers starting "CB750FE-*******". the reason I'm confused is cause on one part of my motor its stamped
"CB750F-3103351" and on another part of the same motor its stamped "CB750E-3103351". I just wanna know cause I wanna by an 836cc kit and I wanna buy the right kit for the right motor. Thank you
Offline cameron
Re: Engine numbers help
« Reply #1 on: May 27, 2010, 12:59:36 PM »
http://www.sohc4.net/index.php?q=content/cb750
the E-number would fit here:
http://www.sohc4.net/index.php?q=node/89
as a 78 k8.
Maybe it was swapped in at some point?
« Last Edit: May 27, 2010, 01:02:53 PM by camn »
1976 CB550F
Offline lone*X
« Reply #2 on: May 27, 2010, 01:02:45 PM »
Try this one:  http://www.sohc4.net/index.php?q=content/cb750
Click the various models for the model guides which show the engine and frame numbers.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline bobbed_750
« Reply #3 on: May 27, 2010, 01:03:26 PM »
Yeh been there just looking for someone that knows a little more than me to just confirm since on my motor I have an F and an E. Its hard to match it with a Frame number since it was just the motor that was pulled from the donor bike almost 10 years ago and put into a custom frame.
Offline cameron
« Reply #4 on: May 27, 2010, 02:13:34 PM »
Where are the numbers located exactly?
1976 CB550F
Offline bobbed_750
« Reply #5 on: May 27, 2010, 03:20:27 PM »
Not really sure so far this has just been an email thing between me and the guy selling it I'm in virginia visiting some friends. I haven't actually picked the bike up. I call him and see where they are stamed does that make a difference in what bike they came off of? Here are the pictures he sent me
« Reply #6 on: May 27, 2010, 09:19:44 PM »
I've never seen an engine with 2 sets of numbers?? Looks like the same pix with a closer view.
I'm seeing cb750E. I do not believe the F's actually had the F stamped into the engine serial number, just on the steerin neck and VIN plate. Without looking up the engine numbers myself, I'd be tempted to believe that is a 78 K engine. It will NOT match the frame number.
« Reply #7 on: May 27, 2010, 09:39:25 PM »
According to the links provided by camn and lone x, your motor is a '78 F3: starting engine # 3100001. K8 starting engine # 3000001
Offline cameron
« Reply #8 on: May 27, 2010, 10:00:35 PM »
I agree.
they both look like 'E's to me too.
Maybe some sand in the stamper or something?
You should wait to get your parts till you can measure yourself, maybe?
1976 CB550F
Offline bobbed_750
« Reply #9 on: May 27, 2010, 10:04:24 PM »
lol the more and more I look at the pictures the more I see 2 e's also. I deff will not be buying any parts till I can know for sure when I get back to cali and pick up the bike. thanks to everyone for the input though.
« Reply #10 on: May 27, 2010, 10:18:21 PM »
You're welcome! And thanks to those that made the info easily accessible! :)
