Author Topic: chain question cb550f  (Read 1231 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: May 27, 2010, 01:33:38 PM »
I have a new chain for my cb550f. Two questions. 1. If the chain seems about twenty links too long, is it the wrong chain or am I missing something? 2. It is an o-ring chain which seems to be so wide that it rubs against the engine case. Should i not be using an oring chain on this model and year? Thanks
Offline Gordon
  • 750K1, 550K2
Re: chain question cb550f
« Reply #1 on: May 27, 2010, 01:36:37 PM »
You're correct in thinking that you shouldn't use an o-ring chain on a 550.  It's too wide and some have had issues with them rubbing a hole in the engine case.
As for chain length, too long is fine because you can always remove as many links as you need to.
Offline robdrobd
  • Who? Me?
« Reply #2 on: May 27, 2010, 01:40:49 PM »
Well, no sense in removing links as it is an o-ring chain.  :o Do I need a special tool to remove the links?
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: May 28, 2010, 01:40:28 AM »
Lots of info here on the topic for 550s.
http://forums.sohc4.net/index.php?topic=65509.0
As far as removing links, I've always just filed/ground the rivets/pins on one side & punched the link out of the side plate with a pin punch. They're not too tough, give it a go.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
