Author Topic: 75 cb550f rich on all cylinders  (Read 838 times)
Offline gerry113377
« on: May 27, 2010, 03:56:32 PM »
I have clean and synched the carbs and tank valve and cleaned the air filter but went ahead and ordered a new one (but haven't got it yet).  Timing and charging is good.  It runs good for 5 minutes after I clean the plugs, then they foul up on all cylinders.  It does NOT have a stock exhaust.  They are 2:1 on each side.  It is loud so I don't think there is much packing in them but I love the way it sounds.  But if it is absolutely necessary to repack I guess I'll do it.  Haven't checked plug gap yet but will do it tomorrow.  They are new plugs  d7ea ngk.   Anything else I can do?  Do i need to repack?  Like I said I love the sound.
Re: 75 cb550f rich on all cylinders
« Reply #1 on: May 27, 2010, 06:40:34 PM »
Paper filters can only be "cleaned" so many times.  Their job is to trap particles, which they do very well.
They can never be completely cleaned.   That's why Honda has a yearly replacement schedule.
A restrictive filter deepens the carb throat vacuum, which causes greater flow from the metering jets relative to the air passing through them.  Ergo sooty spark plugs.
Offline gerry113377
« Reply #2 on: May 30, 2010, 02:58:03 AM »
Just want every one to know problem solved by switching to self cleaning iridium plugs (ngk).  They were expensive but did the trick.
Offline ieism
« Reply #3 on: May 30, 2010, 03:36:05 AM »
Solving a rich condition with "self cleaning plugs" :-\   Great.
I have iridium plugs myself, can't see how this would solve a rich condition. They're just plugs. Maybe a self cleaning airfilter would be a better solution ;)
---cb550---
Offline gerry113377
« Reply #4 on: May 30, 2010, 04:04:15 AM »
I can at least drive the bike now until I have the time and money to figure it out.  Before I couldn't even go up a hill without it wanting to die.  Now it runs like a champ.
« Last Edit: May 30, 2010, 04:06:10 AM by gerry113377 »
