Author Topic: EDIT: Starting attempt #2...SHE RUNS!!! No more issues!!  (Read 4461 times)
Offline Scott S
Re: EDIT: Starting attempt #2...SHE RUNS!!! (but still has issues!)
« Reply #25 on: May 31, 2010, 10:02:10 AM »
 I love it when it's something obvious!!
 Just got back from the carb guys shop. Pulled the float bowl on #1 and found the slow jet loose and hung up around the float.
 He still has all the original jets and will clean and inspect them and re-use them if they pass muster. The O-rings in this kit are already showing signs of getting soft and goopy, too. He has an assortment of the proper fuel resistant O-rings and will replace them as well.
 He's going to re-check the float height, bench synch and check the springs in the linkage holder arms. He soda blasted the carbs and wants to make sure there's nothing in there that would be keeping the RPM's from dropping back.
 I'm pretty sure it's ALL related to the lack of slow jetting in the carb.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: EDIT: Starting attempt #2...SHE RUNS!!! No more issues!!
« Reply #26 on: May 31, 2010, 07:10:45 PM »
 Back together and smooth as a top! Well, as smooth as I can get her on the centerstand in the garage. As soon as I get the master cylinder kit in, I'll rebuild the brakes and take her for a spin.
 Idles well and sounds good now!
'71 CB500 K0
'81 Yamaha XS650
Offline fastbroshi
  • Puppet
« Reply #27 on: May 31, 2010, 08:30:53 PM »
Cool, glad you got it sorted.  It was beginning to sound like an odd one.
Just call me Timmaaaaay!!!
« Reply #28 on: May 31, 2010, 11:57:21 PM »
Carquest matched my 750 o-rings, I have 12 more there waiting for me now.
