Author Topic: I must have done something wrong...  (Read 2425 times)
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« on: February 04, 2006, 09:07:44 AM »
I de-rusted the spare tank last night.  I used 'The Works', which does in fact work.  It was clean as a whistle last night.  This morning it has a full coat of surface rust back on it.  Maybe I didn't dry it good enough?  Should I have coated it with something right away - not implying KREEM, but a light coat of some sort of protectant until it's time to use it?
I'm going to have to re-do this, but need suggestions so I don't do the same thing twice.  Thanks.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline DrMark
Re: I must have done something wrong...
« Reply #1 on: February 04, 2006, 09:15:19 AM »
Sounds to me like a case of flash rusting....bare metal needs to be coated...
1978 CB550K
1983 CB650SC Nighthawk
Offline csendker
« Reply #2 on: February 04, 2006, 09:18:41 AM »
Exactly my point.  But with what?
supersport_CB400F
« Reply #3 on: February 04, 2006, 09:18:54 AM »
My NOS tank has a coating of light oil inside and hasn’t rusted after 30 years smells like 3 in 1 oil.
Offline csendker
« Reply #4 on: February 04, 2006, 09:20:35 AM »
I was thinking oil of some sort.  Any repercussions when it's time to use?  Need to clean it out before or just fill with gas?
supersport_CB400F
« Reply #5 on: February 04, 2006, 09:24:05 AM »
Mr Honda put the oil in so no harm will come to the inside of the tank I'm just going to rinse it out with some petrol before I use it.
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #6 on: February 04, 2006, 09:26:19 AM »
This is one reason why I prefer phosphoric acid to most other treatments - it doesn't flash rust near as readily.  I've used phosphoric acid based panel prep on sheet metal that has had no other treatment and has not developed surface rust in about 5 years of sitting in my garage and I don't live in a dry place.
As for having to clean out the oil before use, don't worry about it - a surface coating won't have any effect on your fuel.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: February 04, 2006, 09:32:05 AM »
I agree in terms of phosphoric based products, if available, try "The Must for Rust." Take a look at this earlier thread.
http://www.sohc4.us/forums/index.php?topic=6437.0
Offline csendker
« Reply #8 on: February 04, 2006, 09:33:39 AM »
I JUST tossed out the bottles for the Works.  What's in it?  Phosphoric or Hydrochloric acid?
Offline heffay
« Reply #9 on: February 04, 2006, 09:34:59 AM »
so maybe they're still in the trash?   ;)
Offline csendker
« Reply #10 on: February 04, 2006, 09:36:08 AM »
Nope.  Garbage Truck came yesterday.  Thanks for the thread, I had read that one, but it didn't really go into much detail about any after-cleaning coating.  However, after reading again, I does say the Works is HCl.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #11 on: February 04, 2006, 09:40:06 AM »
How long are you planning to store it after cleaning before using it? Use phosphoric based and if not long, just rinse thoroughly and dry. If it might be months, I would go ahead and use a thin coat of oil.
Offline csendker
« Reply #12 on: February 04, 2006, 09:47:10 AM »
Nothing I do is fast.  I'm going to re-clean (I'll try the Ph. stuff) and oil for good measure.
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #13 on: February 04, 2006, 05:41:41 PM »
the Must does use phosphoric acid as a primary ingredient
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Kelvin8
« Reply #14 on: February 04, 2006, 09:18:22 PM »
After I derustified my tank, I coated it with 2 stroke motoroil, the kind you mix with the gas. It's formulated to burn, and since I have a chainsaw I have plenty on hand. You can buy 2 or 4 oz bottles at HD or Wal-Mart (8oz there). Works great.
Offline csendker
« Reply #15 on: February 04, 2006, 11:23:15 PM »
I wound up with Phosporic Plus from HD.  Cleaned everything up real nice, and ended up with a light coat of oil.  Now I just have to figure out what to do with the outside of the tank.
One word of caution though.  Don't do like me and use the petcock as a 'stopper'.  I no longer have any metal between the regular & reserve ports - all eaten away.  Bummer.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: February 05, 2006, 03:18:37 AM »
How long did you leave the Phos. in there?
Offline csendker
« Reply #17 on: February 05, 2006, 09:58:21 AM »
The first time around I used the HCl for a couple of hours.  I noticed deterioration, but thought that's how I got it.  The second time with the Ph, another couple of hours and 'poof'. I'll post a pic later.
It didn't take long at all.
Offline csendker
« Reply #18 on: February 05, 2006, 10:50:17 AM »
As promised...
It still works, but there's no difference between normal & reserve; which may lead to some nasty surprises.  Oh well, maybe I'll use it for a 'tune-up tank' stopper.
Offline csendker
« Reply #19 on: February 05, 2006, 10:53:51 AM »
On to the next tank (my 175).  Not wanting to trash this one, I want to take the petcock off first.  It's one of those 'screw' type.  How the heck do I get this thing off?
« Reply #20 on: February 05, 2006, 02:04:00 PM »
Remove the "bowl" and the screen behind it,  You should then see a screw or two to remove the petcock body from the tank.
Offline csendker
« Reply #21 on: February 05, 2006, 07:49:16 PM »
Bingo.  Thanks TT.
