Author Topic: Floppy clutch lever fix.  (Read 764 times)
« on: May 30, 2010, 11:22:10 AM »
 I am tired of the flopping lever on the CB 750. I have already shimmed it.
 I think I have a cure, but it involves, drilling &  tapping the lever and adding a piece. It should tighten everything up and last twice as long.. May not want this on a  restored stocker, but would be great for everyday rider, or custom bike..
 I will have to machine either a shouldered bolt, or spacer & screw kit..
 will post more soon, if you got questions, ask..
Offline Old Scrambler
Re: Floppy clutch lever fix.
« Reply #1 on: May 30, 2010, 12:25:12 PM »
Hey Frank.......just install a new unit!  Honda issued clutch levers with brass sleeves for the CL72 & CL77 models.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: May 30, 2010, 02:31:15 PM »
I have shimmed them, sleeved them, seized them..& squeezed them..........
 I am done with the stock crap..
 I am working on a fork type pivot, that has near double the bearing area, but at least 3X harder to move up and down (ie, wear the sides out).. will pull in just fine.. In a perfect world, with a straight on pull, the stock design would hold up...
