Author Topic: Battery replacement nuts and bolts  (Read 1126 times)
Offline Hush
« on: May 30, 2010, 07:06:49 PM »
Anyone found a replacement for the standard nuts and bolts that attach our battery posts to the cables?
Mine just got eaten by the "pretty blue acid fairy", I got them off but will need to replace them and while I have a heap of standard Honda nuts and bolts I was wondering if stainless steel or something else would work better?
Re: Battery replacement nuts and bolts
« Reply #1 on: May 30, 2010, 07:40:31 PM »
One caution if your posts are the type where the bolt enters from above, and the nut is held captive inside the post: make sure the bolts aren't too long. If they are, it will break the post when you tighten them down. :(
« Reply #2 on: May 30, 2010, 08:30:16 PM »
Stainless should not be attacked by the acid.
Offline Hush
« Reply #3 on: May 30, 2010, 09:53:07 PM »
Cheers Bobby, I've got stainless so I'll give them a go plus add a big dollop of grease on them to deter the "pretty blue acid fairy". ;D
« Reply #4 on: May 31, 2010, 05:56:18 PM »
Yeah a bit of grease should help a bit. I have been lucky have not had any flowers grow on mine yet................yet
Offline 750goes
  • it will live
« Reply #5 on: May 31, 2010, 10:23:00 PM »
simple tip for you Hush,
sorry for the hijack
you know those little nuts that keep falling out and are hard to get in the right spot for the bolt,
get a small length of plastic tubing cut it the horizontal length of the post and squeeze it in with the nut uppermost.
then put your bolts in - never lose your nuts again...
and get a spray can of battery terminal protector - never see those fuzzy bits again..
Offline Hush
« Reply #6 on: June 01, 2010, 12:25:25 AM »
Yep I use the 1/2 plastic tube idea already (didn't I invent it?) ;D but will invest in some battery spray if they make the stuff here in Godzone. :)
