Author Topic: four into one intake  (Read 1866 times)
Offline country joe
« on: May 31, 2010, 05:07:29 AM »
 Hey y'all! I had this idea that will be total blasphemy to most of the sohc members, but I think would work great. Has anyone ever heard of anyone selling or currently making 4 into one intake manifolds for sohc fours? I have seen a couple in The Horse chopper magazine, but I believe they were totally homemade. The only reason I thought of it was it would take a lot of the work out of adjusting the carbs and such. Just easier maintainenance, and simplicity overall. I know where I can score a Mikuni HS 42 real cheap, and figured why not a four into one intake with this sucker on it? Hell, I don't know, the Mikuni might be too small, but I just wnated to kn ow if anyone here has either done a four into one, or knows where I can get one. Thanks
'78 Honda CB550K
'79 Yamaha IT400
'74 H-D Sprint 350 (basket case)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
Re: four into one intake
« Reply #1 on: May 31, 2010, 05:41:51 AM »
QUADRAJET BABY!!!!!
Seriously, no, I don't know where you can get one.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline crazypj
  • I'm brill, me
« Reply #2 on: May 31, 2010, 06:20:22 AM »
Good reason not to do it is it runs rich on middle cylinders and lean on outer ones, plus you lose a bunch of performance.
 If you want a low HP single carb bike, get a CB125
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
« Reply #3 on: May 31, 2010, 07:33:31 AM »
I have seen it. No, there is no place to buy one.  They do run lean on the outside cylinders.  If anything, you should think about twin carbs instead of 1>4.  Your rings will thank you.
333:  Think "Shakeweight".
Offline gerhed
« Reply #4 on: May 31, 2010, 11:08:13 AM »
4 into 2 from cycle-x
Works well
          83 XL600R in CB360 Frame
Offline faux fiddy
  • bike in a box
« Reply #5 on: May 31, 2010, 04:51:18 PM »
I'd like to see any fuel injetion/ megasquirt conversions, if any were around. Even better than a carb.
I've read about the newer mikuni ibeat FI and the system doesn't require high pressure fuel pumps and lines. It's common on indonisian honda scooters; virtually non-existent  elsewhere and unobtanium as an after-market tinkerer's jewel. I think this stuff could have wonderful application on the SOHC-4  if you could get it, and it could be 1 n2 4, 2  into 4, or 4 n2 4.
« Last Edit: May 31, 2010, 05:35:06 PM by poor boi »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #6 on: May 31, 2010, 05:02:54 PM »
I'd ike t see any fuel injetion/ megasquirt conversions if any were around. Even better than a carb.
I've read about the newer mikuni ibeat FI and the system doesn't require high pressure fuel pumps and lines. It's common on indonisianhonda scooters; virtually non-existent  elsewhere and unobtanium as an after-market tinkerer jewel. I think this stuff could have wonderful applicatin on the SOHC-4  if you could get it, and it could be 1 n2 4, 2into 4, or 4 n2 4.
Do a search , there's a couple of guys on here running microsquirt systems...
This thread is quite long but very informative.
http://forums.sohc4.net/index.php?topic=30624.0
Offline faux fiddy
  • bike in a box
« Reply #8 on: May 31, 2010, 06:00:17 PM »
Not really meaning to threadjack this , but if doing something different thanstock maybe FI is the way to go.
Here's what I'd like to do for a conversion. One on each cylider, self contained with it's own fuel pressure.
http://www.mikuni.co.jp/e/iBeat/index.html
Offline country joe
« Reply #9 on: June 01, 2010, 08:03:34 AM »
thanks for all the input guys it has been very helpful. A fuel injection system would really kick ass! I agree there. I'm gong to check out cycle x I think. Again thanks all!
'78 Honda CB550K
'79 Yamaha IT400
