Author Topic: Centerstand stop for a MAC exhaust  (Read 6452 times)
Offline Scott S
« on: May 31, 2010, 11:45:33 AM »
 Here's how I modified the bracket that came with my MAC 4-1 so I could use the factory center stand. This is for a '71 CB500, but the idea is the same for just about any bike.
 One trick I like to do is attach a rubber bumper of some sort. I dig through my jar-o'-goodies in the garage and find something. A rubber sleeve from some shocks, a large gasket,etc. This one is a piece of rubber that I cut off of a crank case breather. I like to drill a counter sunk hole in the rubber (using a large drill bit or an abrasive cylinder on my Dremel tool) so that the nut/bolt don't hit the center stand. Just drill the "foot" of the bracket to fit whatever nut and bolt you use.
 The bracket is straight with a 90 degree bend at the bottom. Being straight, it hits the muffler before I could even tighten the nut. I put it in my vice and bent it as needed to clear the muffler and hit the center stand.
 I use locking nuts, but I still have to adjust them from time to time. The vibration from the bike and the force of the stand hitting it will eventually cause it to shift some.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
Re: Centerstand stop for a MAC exhaust
« Reply #1 on: June 16, 2010, 03:45:00 PM »
What I did on the 750's is pull the stand, leaving the clamp bolts in and just loosened. When I need the stand, I pop it on real quick(without spring) and it works just fine. Put a brick in front of the front wheel to compensate for the spring.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
