Author Topic: splitting cases and rotor removal  (Read 757 times)
Offline egar
« on: May 31, 2010, 03:31:31 PM »
There's a lot of crud at the bottom of my crankcase. I was hoping to blast it all out with cleaner so I could avoid cracking the cas of my 1970 750. My question - can I split the cases without removing the rotor? I just want to get in there and clean the crud. If I must remove the rotor, does it tighten counterclockwise? From what I'm reading, it sounds difficult to remove the bolt on the left side that holds the rotor on....
Ed
sohc4
'04 ST1300, '70 cb750KO
Offline Doctor_D
Re: splitting cases and rotor removal
« Reply #1 on: May 31, 2010, 03:38:33 PM »
Yes, you can remove the crank without pulling the rotor.
Take care,
David
1978 CX500
1971 Norton Commando
Offline egar
« Reply #2 on: May 31, 2010, 03:46:22 PM »
Thank you, Dr. D! I was hoping that was the case.
sohc4
