Author Topic: stripped oil filter housing bolt on k5  (Read 1014 times)
Offline dariusk5
« on: June 01, 2010, 09:33:57 AM »
im not the most the most mechanically knowledgeable person, how should i go about getting it out, im 2/3 done draining the oil and really want to finish before it rains. thankyou in advance for your help
« Last Edit: June 01, 2010, 09:38:26 AM by dariusk5 »
Offline Johnie
Re: stripped oil filter housing bolt on k5
« Reply #1 on: June 01, 2010, 09:38:31 AM »
Man, that is a bummer. Do a search on this board as there is an extensive post about your next move to get it out. Here is one post I found and there are more.
http://forums.sohc4.net/index.php?topic=30611.0
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dariusk5
« Reply #2 on: June 01, 2010, 09:49:55 AM »
thanks johnie in my panic i neglected to search this topic before posting
Offline Johnie
« Reply #3 on: June 01, 2010, 11:17:00 AM »
No problem man. Good luck with your fix. Let us know how you solve it. Depending on how bad that bolt is I often wondered if a pipe wrench could get enough bite on it.
Oshkosh, WI  USA
Offline fmctm1sw
« Reply #4 on: June 01, 2010, 02:54:52 PM »
I had to hacksaw mine off.  That was before I owned a dremel tool though.  I often wonder how I ever lived without a dremel tool...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #5 on: June 01, 2010, 05:44:12 PM »
Hammer a smaller size 12 point socket or 6 if you can on the end,works good when they are really chewed up.It will get a good bite and probably come off and get that new bolt.
Offline dariusk5
« Reply #6 on: June 04, 2010, 10:52:03 AM »
thanks for all your help guys, i made a trip to sears and got some socket type bolt extractors which took care of the bolt really fast next on the list to buy, torque wrench.
Offline Johnie
« Reply #7 on: June 04, 2010, 10:56:08 AM »
Good for you. How about a pic of that K5? We like pics here.  ;D
Oshkosh, WI  USA
