Author Topic: Flasher relay  (Read 1460 times)
Offline Fred T
Flasher relay
« on: June 01, 2010, 02:52:49 PM »
I need some advice in order to determine the problem with my right turning light. When the bike is in idle, I switch the left turning signal and works fine, but when I switch the right turning signal ,stays on , no blinking. The problem dissapear as soon as I rev the bike. I´m thinking the flasher relay is not working properly, but maybe any of you electrical guys have another opinion.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: Flasher relay
« Reply #1 on: June 01, 2010, 03:26:44 PM »
The old mechanical flashers rely on voltage to
flash, so that is normal.
When the they slow down it is usually time for a new flasher.
Bikes parked out front mean good chicken-fried steak inside.
Offline OldSchool_IsCool
  • Really feeling like an
Re: Flasher relay
« Reply #2 on: June 01, 2010, 05:27:42 PM »
There is prolly a corroded connector in your right turn signal wiring.  Corroded connections are resistive, resistance means a drop in voltage.  Drop too much and your idling engine isn't producing enough voltage to cause the mechanical flasher unit to work properly.
Two things you can do.  First and highly recommended is clean all your connectors.  Repack them with dielectric grease to slow the recurrence of corrosion.
Second option, also highly recommended is to replace your mechanical flasher unit with a modern electronic 3-prong setup.  You will find a green wire hanging loose by your current flasher.  Connect green to ground terminal, black to + terminal and gray to the third.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Re: Flasher relay
« Reply #3 on: June 01, 2010, 05:50:48 PM »
Much less than full charge and you will see this. Charge the battery and report back.
Offline bender01
Re: Flasher relay
« Reply #4 on: June 01, 2010, 07:11:45 PM »
The new flasher relays are between 6-15$ at autozone.  If its original its probably tired.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Fred T
Re: Flasher relay
« Reply #5 on: June 02, 2010, 08:14:52 AM »
Thanks all for the replies. I´ll get a new one, they are cheap.
