Author Topic: dowel pins  (Read 1091 times)
gsmittles
dowel pins
« on: June 01, 2010, 06:32:23 PM »
I beginning to reassemble my Honda 750 engine and the service manual refers to dowel pins that go outboard of the exhaust on the posts in the block of the engine.  It's been a couple months since I took it apart and I don't remember seeing anything that went there.  There is a recess around the post.  Help is appreciated.
Offline Kevin D
  • SE Michigan
Re: dowel pins
« Reply #1 on: June 01, 2010, 06:59:52 PM »
gsmittles, I cant make out what model you have there, but heres a partsfiche for a K1:
http://www.cmsnl.com/honda-cb750k1-four-usa_model14354/partslist/E05.html
Items 10 and 11 locate cylinder to case and head.
9430112150
PIN,KNOCK 12X15   (cyl to case)
9430112220
PIN,KNOCK 12X22   (cyl to head)
Is that what you are after?
« Last Edit: June 01, 2010, 07:08:16 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Kevin D
  • SE Michigan
Re: dowel pins
« Reply #2 on: June 01, 2010, 07:15:49 PM »
Okay, heres for a 78k:
http://www.cmsnl.com/honda-cb750k-750-four-k-78-us_model7244/partslist/E++03.html
Looks like item 8 is the locating dowels:
9430112180
PIN,KNOCK 12X18
Item 2 and 3 are seal and special pin to seal oil path return.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
gsmittles
Re: dowel pins
« Reply #3 on: June 06, 2010, 11:58:04 AM »
Thanks.  What is the best way to get the pistons back into the jugs?  Looks like a two person operation.
co425
Re: dowel pins
« Reply #4 on: June 06, 2010, 12:02:30 PM »
Yep at least two people. Put two cyliders up on the upward stroke and use your fingers to get one ring on both pistons in at the same time. Be carefull because its easy with new rings to pop one out of the grove and snap it off. Do this until all three are in. It should take almost no force once you have the ring compressed enough to slide into the bore. Get the two pistons in and rotate the motor over holding the cam chain up then work the other two in. Also use spray on copper coat for the base head and valve cover gaskets great stuff no leaky.
gsmittles
Re: dowel pins
« Reply #5 on: June 06, 2010, 01:33:55 PM »
OK.  Thanks.
