Author Topic: Lazy man carb maintenance  (Read 1027 times)
TheDodger
« on: June 02, 2010, 11:40:54 AM »
Hi guys.
I bought a 1982 CB 750 FB last week.
It has a 4 into 1 Motad exhaust system, and it runs pretty badly.
I have to whack the idle speed up to about 1500 to stop it cutting out. but even then it fluctuates.  The bike will pull cleanly from a stand still, but sometimes it bogs in the midrange, other times it pulls all the way to an indicated 110 MPH on the clocks and only stutters at that speed (could be hitting the limiter).
Now I've spent many an hour tuning a two stroke carb (on a Aprilia RS125 which many of you US guys probably won't know of because it wasn't officially imported), but I want to quickly sort these carbs out and get as close to fault resolution before I start meticulously trying different jets and needle heights. I want a base setting.
I believe this erratic behaviour is probably caused by an air leak, but I sprayed some deodorant around the carbs and the idle speed didn't change.
Basically, in 28 year old carbs on a bike that has seemingly only done 17,000 miles, what do I need to replace straight away without even going in the carbs to have a look?
Cheers.
Offline brandon
Re: Lazy man carb maintenance
« Reply #1 on: June 02, 2010, 11:57:15 AM »
Is the entire ignition system OEM?
TheDodger
« Reply #2 on: June 02, 2010, 04:31:22 PM »
Yeah, I think so.
Anyway, I pulled the carbs tonight.
Notice that one of the inlet rubbers was badly cracked.
Gonna replace the whole set and go into the carbs tomorrow.
Offline fastbroshi
  • Puppet
« Reply #3 on: June 02, 2010, 06:30:16 PM »
This is a DOHC motor correct?  With all due respect, maybe it should go on the Other Bikes section, or one of the others, but not this one.
Just call me Timmaaaaay!!!
« Reply #4 on: June 02, 2010, 09:17:10 PM »
Well spotted FB.
moved.
Sam. :)
TheDodger
« Reply #5 on: June 03, 2010, 04:13:41 PM »
Sorry I posted in the wrong forum.
Anyone have any advice?
Cheers
