Author Topic: sheer ratings and replacing zinc plated bolts  (Read 1417 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: February 05, 2006, 02:48:09 PM »
somehow, in my careful organizing of everything that came off of my CB550F, i have still managed to misplace some important bolts, such as the upper front engine mounting bolts, and the lower triple tree tightening bolts. the obvious answer to this question would be to err in favor of greater strength, but does anyone know what sheer rating somewhat critical bolts should be replaced with? the NOS bolts say nothing on the heads. is it worth buying bolts with a 7 or 8 sheer rating, or would the run of the mill hardware store zinc plated variety work? anybody have any experience with this? i know with cars this rating can be very important.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
Re: sheer ratings and replacing zinc plated bolts
« Reply #1 on: February 05, 2006, 04:01:48 PM »
Your best best is to use grade 5 bolts at a minimum.  Do you know the torque specs for the bolts you're replacing?  That will tell you a good bit about the grade you need to use.
Offline paulages
  • 1976 cb735
« Reply #2 on: February 05, 2006, 10:20:05 PM »
no, i haven't looked into that yet. i figured that would send me in the right direction, though i assumed that it wouldn't specify a shear rating. i know it's very important for head studs, etc. but i was unsure how much it will matter on certain motorcycle parts. it also seems to me that automobile specs. place much more emphasis on proper torquing of bolts when assembling than with motorcycles. maybe that's just the manuals if dealt with???
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
  • Administrator
« Reply #3 on: February 06, 2006, 02:45:46 AM »
I'm pretty sure that there are torque specs in the manauls, but I believe the motorcycle manuals might just show specs for different size bolts in general and specific critical fasteners.  If you look at bolt charts, you'll see that different grades of bolt in the same size have different maximum torque ratings.  Combine that with Honda's specs and you'll have a minimum grade for the particular application.  Are you sure there are no grading marks on the heads of the OEM bolts?  You probably already know this, but If there are no numbers, there are often slash marks.
Offline paulages
  • 1976 cb735
« Reply #4 on: February 07, 2006, 09:53:30 PM »
i'll double check for slash marks when i get to my shop next, but i dont think there were any. thanks for the cross referencing advice, glenn.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline dusterdude
« Reply #5 on: February 08, 2006, 04:30:09 PM »
i agree,grade 5 should be more than enough
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
