Author Topic: Which intake manifolds to use?  (Read 618 times)
Offline mrrch
« on: June 03, 2010, 01:24:50 PM »
I have a 76 CB750k engine with 77 CB750k carbs, does it matter which intake manifolds to use? 76 & 77 have different part numbers listed. I will be using pod filters instead of the stock airbox.
my build
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Which intake manifolds to use?
« Reply #1 on: June 03, 2010, 06:47:05 PM »
The rubber carb insulators for the 76K are about a 1/2 inch longer then the ones for the 77/78K if that helps.
.............Paul
Offline mrrch
« Reply #2 on: June 03, 2010, 07:33:39 PM »
Thanks for the info, I'll go with the 77/78 ones to keep the intake tract short.
Ray
my build
« Reply #3 on: June 03, 2010, 07:55:00 PM »
 Better have a set of 77/78 carbs handy..
Offline oldyzracer
  • Andrew Olson
« Reply #4 on: June 03, 2010, 08:43:21 PM »
Ha ha! These forums are very entertaining if you take the time to read them.
Currently "restoring" a 1973 CB750K
Riding a restored 1981 YZ250H and a VT500FT Ascot
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #5 on: June 03, 2010, 08:44:54 PM »
 who can read ?  i just look at pics ! :o ;D :D :-*
I like berries.
