Author Topic: Project Red Headed Step Child ruh roh damage!  (Read 30470 times)
Offline gnarlycharlie4u
  • Far from being an
Re: Project Red Headed Step Child
« Reply #25 on: August 18, 2010, 09:09:30 AM »
Excellent.
It's good to see another late model owner loving his bike.
I got a '77 earlier this summer and still haven't manages to get it running.
Strangely this hasn't deterred me from working on it but has instead motivated me to pour every spare dollar I have into giving it an overhaul :D
Offline HedNut
  • Underwater Basket Weaving
« Reply #26 on: August 18, 2010, 10:03:10 AM »
Hey Gnarly! Excellent to hear!~ I hope we get to see this 77' come together!  Cheers!
Offline MasterChief750
  • Detonation
« Reply #27 on: August 21, 2010, 09:28:58 AM »
finally an update got the block on today and the head is soaking to remove head gasket remnants.
got a tip from someone that chem dip really softens up gaskets. it works! he said over night helps i let them sit for  a week really loosened stuff up.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
  • Detonation
« Reply #28 on: August 23, 2010, 11:10:14 AM »
decided today i will use the stock airbox for the time being until i have the funds to buy a multitude of jets. still going to cut down exhaust, i like the 4-4 pipes but just too quiet. have some interesting ideas for them.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #29 on: September 06, 2010, 10:43:41 AM »
got a lot of work done this weekend bike is in the frame and will hopefully have it running by the end of next weekend. just got to work up the courage to go at the carbs again. nd find my sandpaper so i can clear the tank. im so done with messing with that. crap forgot i need to paint the fuel door. need me 3qt of the finest 10w-30 motorcycle oil an oil filter swtiching to dot5 brake fluid and to weld up my modofied exhaust. and drummroll please here are the pics.
head after i cleaned the gasket, chemdip is the best
head on getting ready to tackle valvetrain
valvetrain assembled and timed with crank
frame ready for motor
tada. only nicked the paint a little by rear mounts and crushed finger between frame and motor
what i have to deal with at some point. and my NOS headlight bucket installed
yep learned that you should install oiltank and lines before you put the footpegs and brake pedal in.
new bars superbike bars. i like em just a few lines are a little bit too long.
ugh
tach is done, just need to finish speedo and il post some pics
where im cutting the exhaust off at.
thats all i have to update right now will be done soon hopefully so i can rinde this year yet. may have to brave the really cold weather.
I AM THE STIG
Sam is THE STIG
  • Detonation
Re: Project Red Headed Step Child UPDATES!!! almost done.
« Reply #30 on: September 07, 2010, 06:39:31 AM »
i am missing the washer that goes in the oil filter housing between the spring and the filter
its number five does anyone know what the measurements are for the washer i want to save money i know its only like 3 bucks for the part but if i can pick it up for a buck at the local hardware store i would prefer to do that.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #31 on: September 07, 2010, 03:32:54 PM »
one gauge down one to go.
I AM THE STIG
Sam is THE STIG
Offline Toxic
« Reply #32 on: September 08, 2010, 05:43:45 AM »
Take part 4 and part 7 to Home Depot and you will find a washer the will fit perfect.
That's where I found mine.
  • Detonation
« Reply #33 on: September 08, 2010, 06:31:15 AM »
sweet thanks
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #34 on: September 08, 2010, 08:24:20 AM »
Okay I seem to be missing one of the headlight nuts. The ones that have the turnsignal ground wire on them. Anyone have one as I found bolts with the correct pitch for them. Otherwise I will resort to making one.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #35 on: September 12, 2010, 11:55:27 AM »
got the washer issue figured out. ended up finding my oem one. couldnt find a washer at the hardware store that would work anyways. wired the bike up and couldnt get any of the lights to work but i think that is because i dont have the coils hooked up or the ground wire that is grounded there. motor turns over but carbs and exhaust are not finished so no start. getting very close. will post some pics later. off to HF to get a angle grinder and a cutoff wheel to work on the exhaust.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #36 on: September 12, 2010, 05:16:57 PM »
went to HF and got a angle grinder and some cutoff wheels. hehe those are fun i wish i had more stuff to chop up. better not go near the frame with that cutting wheel i might get a little carried away. ps dont buy the cheap hf cutoff discs the centers are really crappy and fall apart and throw metal all over the place. heres som pcs of todays progress.
im going to cut the end caps so they are the correct size for the pipes to where i cut them down and weld them back on then cut the centers for a little more free flowing. got to reshape the ends as 2 of the pipes the back sides are indented at the factory and where i cut there is just a smidge of that. i think originally the pipes had 5 chamberes, now they will have 2. cut them in the 3rd chamber and removing the baffle there so there will be two.
« Last Edit: September 12, 2010, 05:26:40 PM by masterchief1112 »
I AM THE STIG
Sam is THE STIG
Offline HedNut
Re: Project Red Headed Step Child UPDATES!!! Exhaust started
« Reply #37 on: September 13, 2010, 05:51:48 AM »
Awesome!!! You're crazy like me cutting your megas up!!  :D  Excellent buddy...look forward to hearing those bad-boyZ
  • Detonation
« Reply #38 on: September 13, 2010, 07:17:46 AM »
chopping is so much fun. the extra parts from the exhaust is now in shards because i fel the need to cut up something else. something satisfying about. now if i can only get my welder to work. anyone know where i can get a thermal cutoff switch for a clarke turbo weld 100
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #39 on: September 13, 2010, 08:32:40 AM »
Sourced parts for my welder man flux core is expensive if I had money for a bottle and reg I would get that I would like to hear her rumble next weekend so I may be having my future father in law do the welding for me. Gonna paint them black and wrap the headers. Should look neat.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #40 on: September 20, 2010, 07:39:55 AM »
well got some headers off of a buddy to start her up yesterday and shot some either in there nothing. started troubleshooting. have an issue with the choke linkage wont close all the way. and NO SPARK. both coils. must have hooked something up wrong. didnt troubleshoot that i was soo pissed i just packed up and when home. got a random part tat i have no idea what it goes to it holds something in place somewhere. just dont remember. also turn signals are messed up. they dont blink and the relay goes nuts the second you turn the bike on. looks like i need to go through the wiring again. tank and exhaust almost done. paint on the tank is ok. wasnt looking for perfection. need to adjust points i think as well. chain is on. found a master for a non oring 630 and made it work. will convert to a 530 this winter. oh need to get the seat done too. may reshape the foam a little dont know though.
I AM THE STIG
Sam is THE STIG
Offline HedNut
« Reply #41 on: September 20, 2010, 08:19:01 AM »
Wiring is the #$%*s... good luck dood! Take your time with a test light and a Volt meter...they're magical for helping you find the devilish issues.
I'm not sure about the relay...but you may have a power and a ground hooked up right thru the relay itself heating it up super fast?
Cheers!
  • Detonation
« Reply #42 on: September 20, 2010, 08:32:39 AM »
Hooked it up exactly how it was originally. Maybe I have it screwed up in the headlight mess o wiry ball of death and pissoffedness. Will have to go through everything again. Won't hurt. Past couple times I did it I found something wrong. Turns over at least.
I AM THE STIG
Sam is THE STIG
Offline HedNut
« Reply #43 on: September 20, 2010, 08:35:02 AM »
The birds nest in the hl bucket scares me... I slaughtered as many wires as I could from mine..and there's still too many.  Good Luck my friend....I have good faith in you!
  • Detonation
« Reply #44 on: September 20, 2010, 08:58:24 AM »
Thanks hednut. Notes to self
Brake fluid and bleed brakes
Fix carbs
adjust pionts
Sandblast and paint seat pan.
Take in seat for upolstery
Fix turn signals
Fix spark issue.
Paint and install center stand
Exhaust
Finish paint on tank.
Finish tachometer
Points gasket. Sync carbs.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #45 on: September 26, 2010, 02:34:43 PM »
well got electrical gremlins galore. still no spark. first i figured it was because the points were not closing. now they are and still no spark. redid all the wiring again still no spark. cant find where its wrong. no the kill switch is not on. weird winker relay issue. the relay starts clicking when the bike is turned on then stops when you turn a signal on. i need some help anyone near want to help a brother out. good with electronics but never been a trouble shooter. just so frustrating. will give beer for help bike is in hudson michigan if that helps any
I AM THE STIG
Sam is THE STIG
Offline HedNut
Re: Project Red Headed Step Child electrical gremlins need some help
« Reply #46 on: September 27, 2010, 05:24:23 AM »
I wish I was close enough to stop by...sounds like a few beers with the multimeter are needed there to trace draws/grounds etc.... something probably very simple...just to find it!
  • Detonation
« Reply #47 on: September 27, 2010, 07:14:53 AM »
yeah prolly what i will do a few beers in tho and you stop giving a s#!*. ill work through it. still got to finish the carbies and exhaust. still want to reshape the f header i got and run that or the 4-4 prolly wil do both.
I AM THE STIG
Sam is THE STIG
  • Detonation
« Reply #48 on: November 16, 2010, 12:50:39 PM »
ordered all new ignition tired of fiddling with points, coils were shot and plug boots were shot, may be why i had no spark ordered the standard pamco ignition kit for cb750 supply. for 180 bucks to refresh the ignition i couldnt refuse. will post pics with install should be here friday. ill treat you guys to a pic of my tank, pretty much done just  needs another coat of clear and wetsand. time is a premium and havent worked on the bike in the last month
I AM THE STIG
Sam is THE STIG
Offline CB750K_Loon
« Reply #49 on: February 04, 2011, 07:24:24 PM »
Hey masterchief, how is the Pamco ignition kit working for you?  Have you had any hiccups?  As far as U understand, there are no adjustments to make, correct?  Just drop and go?  Will pm you just in case.
1978 CB750K
