Author Topic: Alternatives to Carillo Rods?  (Read 7409 times)
Offline Big Jay
    • CBRzone
Re: Alternatives to Carillo Rods?
« Reply #25 on: June 08, 2010, 06:24:25 PM »
I called Carillo first.  The cheapest I can get them without ordering $35,000 worth of product per year is $1100 per set.
As far as the weight is concerned my guy at Crower claims that they will model the rod for a 315-320 gram weigh in CAD prior to making them.
That is an awful heavy 400 rod. We still talking 400s?
Offline MaaseyRacer
    • Fuelist
« Reply #26 on: June 08, 2010, 10:39:33 PM »
Yes Jay we are talking 400F rods.  I am sure we can work the weights down to be competitive with the other rods.  However, the point here is not to have the lightest possible rods offered here.  The point is to have an affordable set available to 400F owners who want to take advantage of low priced big bore kits out there.
As far as the weights I mentioned before those were based off the photos of the rods someone else posted on the first page.  In review I see those are CB750 rods.  I will mention this to Crower tomorrow.  I am sure when the actual engineering numbers come back from Crower we can get more accurate weights.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #27 on: June 09, 2010, 12:24:49 AM »
Some weights for you.
Crower 400F rod 279 Gr.
Carillo 400F rod 264 Gr.
CB400F Stock B rod 250 Gr.
CB400F Stock D Rod 255 Gr.
A Genuine CB400F RSC rod is around 260 Grams.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline MaaseyRacer
    • Fuelist
« Reply #28 on: June 09, 2010, 09:04:31 AM »
Kevin
Thank you Kevin.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
Offline specweld
« Reply #29 on: June 16, 2010, 11:45:16 PM »
The english supplier is ROBSON ENG. I now have them in my CB400 , they are good people to deal with, ask for Carl.
If you want to see the results of not upping the rods , go to the high performance section and look up 'my CB400'.
The pics are in reverse order, they should show the blown engine and then the new one being built,there are pics which show the robson rods.
Offline crazypj
  • I'm brill, me
« Reply #30 on: June 16, 2010, 11:47:56 PM »
CB350F, stock rods  ;D
 The sand is from 'storage', it is punched out
 Just twist some up out of old coat hangers, it will be 'fine'  :D
PJ
« Last Edit: June 16, 2010, 11:51:10 PM by crazypj »
Offline Kevin
« Reply #31 on: March 04, 2011, 02:10:55 PM »
Kevin
I have a set of Robson Engineering Rods here and just weighed one of them, 326 Gr. including bolts and nuts
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
