Author Topic: My Rickman Engine cases. To clear or not to clear...  (Read 2026 times)
Offline phactory
  • Motorcycle Rescue
« on: June 06, 2010, 07:58:48 AM »
That is the question!  ???
Spent the better part of yesterday being a dirty case polisher!  ;D But the results were so worth it! Should I clear them now? What is the consensus? Is clear out of a spray bomb good enough?
Phil
Re: My Rickman Engine cases. To clear or not to clear...
« Reply #1 on: June 06, 2010, 09:22:06 AM »
I wouldn't do it. I tried "Eastwood Diamond Clear for bare metal surfaces" in the spray can on my front hub after cleaning and polishing. I wiped the hub with acetone, let dry then sprayed. I noticed a place on it, picked at it and it peeled right off. I got the whole hub peeled by hand. Really pissed. Eastwood is supposed to be one of the best. Powder coat clear would be the best choice but I haven't seen any testimonials here. The pieces get baked before coating to sweat out and burn off any residual that has soaked into the aluminum.
Offline phactory
  • Motorcycle Rescue
« Reply #2 on: June 06, 2010, 09:33:55 AM »
Jerry,
 Thanks, the jury is still out but if I do, do it, I will wash them in the sink with lots of hot soapy water and then blow them off with my air compressor. Then I will bake them in the oven so that they are at least 200F, and then spray them. If I use anything, the POR 15 Glisten PC is probably the leading candidate.
Thanks, Phil
Offline Simon
« Reply #3 on: June 06, 2010, 09:42:19 AM »
There is always the SPRAYMAX 2K clear I keep hearing about. Never used the product myself. I am debating on spraying my polished parts also. Will read this thread with interest.
A link to the product  http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
Simon
Offline phactory
  • Motorcycle Rescue
« Reply #4 on: June 06, 2010, 09:50:31 AM »
Simon,
 I will check this stuff out. As with most anything, the preparation is the key!
Thanks, Phil
« Reply #5 on: June 06, 2010, 11:24:14 AM »
I have sprayed some Dupont 380-S cleat coat on aluminum from my spray gun years ago and held up well.Did not do a valve cover-high heat item though.Clutch case block parts OK.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: June 06, 2010, 11:36:17 AM »
Similar experience here.
When I restored my CL350 I cleared all the shiny bits. It turned flaky and pitted looking within a year.
I just finished using paint remover to get rid of the mess that it had become over 3 years. Not a fun job considering it was unnecessary :P
Don't do it !
co425
« Reply #7 on: June 06, 2010, 11:41:45 AM »
I use the High temp ceramic engine enamel clear from Duplicolor. So far so good not an issue with it at all. It is a little delicate. Just dont scrape a wrench across it and it will work fine.
How about powder coat clear. If you dont coat it with something you will have a nightmare hand polishing them all the time.
Offline Simon
« Reply #8 on: June 06, 2010, 11:54:56 AM »
For what it's worth, I put a few coats of car wax on the polished parts this spring. Don't know if it will preserve the shine or not but thought I'd give it a try...
S.
Offline Alan F.
« Reply #9 on: June 06, 2010, 12:07:32 PM »
Anyone have experience with zoopseal?
This stuff would seem to be a viable alternative to paint or powder, since they won't adhere to polished surfaces very well to begin with.
-Alan
http://www.zoopseal.com/
co425
« Reply #10 on: June 06, 2010, 12:17:52 PM »
As seen on TV enough said.  :P
Offline Alan F.
« Reply #11 on: June 06, 2010, 12:35:21 PM »
Actually I first saw it on a PBS show (forget the name and it's been a few years) ...where they restored a forty something Harley, and later a pre-unit Bonneville.
-A
Offline markb
  • When I finish my current project I might be a
« Reply #12 on: June 06, 2010, 12:55:28 PM »
I had a similar experience with the spray can.  Then I tried the Extreme Diamond Clear.  It is very hard and nothing touches it, even aircraft remover.  It's nasty stuff though.  And my covers are more of a satin buff, not mirror polish and it's held up well.  I like the idea of the clear powder coat and I'm going to try it.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline phactory
  • Motorcycle Rescue
« Reply #13 on: June 07, 2010, 05:28:56 AM »
The jury is still out on this one. I know that I am not going to go the clear powder coat route.
Thanks, Phil
Offline Flathead
« Reply #14 on: September 16, 2010, 06:47:37 PM »
Heh Phil.
PJ1 sells a high temp clear that I used on My Rickman engine covers. No peeling. no yellowing, no problems. Warm and dry before applying works best.
Offline Bodi
« Reply #15 on: September 17, 2010, 05:33:42 AM »
Gunkote is my recommendation. I've used the original black stuff and it's amazing. There's a newer product available in clear that I haven't used but if it performs like the black I can't see a problem.
Offline Toxic
« Reply #16 on: September 17, 2010, 05:42:01 AM »
I wouldn't do it ... too many people have not been happy with it.
I would look into:  http://www.sharkhide.com/mpinfo.html
i don't know if it would be applicable for high heat but worth a look.
Offline phactory
  • Motorcycle Rescue
« Reply #17 on: September 17, 2010, 07:27:53 AM »
Flathead,
 Thanks, I have had good luck with PJ1 in the past. I will check it out.
Thanks, Phil
Heh Phil.
Offline domer
« Reply #18 on: September 17, 2010, 08:26:58 AM »
just my 2 cents, if you want pretty polished aluminum, then keep polishing. 1 scratch on the clear and things are going to go south, ive polished every aluminum bit that was cleared, and i keep polishing it. a little mothers once every month or two and its good as new. no clear for me!
