Author Topic: Yoshimura CR Trans ?  (Read 4027 times)
Offline cavebear
« on: June 06, 2010, 02:04:34 PM »
I have what is supposed to be a Yoshimura close ratio trans .There are no identifying marks but one of the gear clusters is clearly machined differently. Old timers tell me what you think.
CB 750 F2           Cb 750 F2        RATIO   Yoshimura?         RATIO
Countershaft        mainshaft                    Mainshaft
Tooth Count         Tooth count                 Tooth count
c1-47 teeth          1-18 t            1-2.60      1-25t             1-1.88
c2-41 t                2-24 t            2-1.70      2-28t             2-1.46
c3-36 t                3-27 t            3-1.30      3-29t             3-1.24
c4-34 t                4-31 t            4-1.10      4-30t             4-1.13
c5-31t                 5-33 t            5-0.94      5-35t             5-0.89
Thanks for your input.
                                Cavebear
« Last Edit: July 13, 2010, 07:36:51 PM by cavebear »
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
Offline fastbroshi
  • Puppet
Re: Yoshimura CR Trans
« Reply #1 on: June 07, 2010, 12:52:46 AM »
On a relative note, in case you haven't seen it.  This site can help you pick and choose your ratios or just figure out what you've got.
http://www.gearingcommander.com/
Just call me Timmaaaaay!!!
« Reply #2 on: June 07, 2010, 07:04:20 PM »
It's easier to get a CR box now than forty years ago, so it may depend if you know how old the engine it came from is whether or not it's Yosh. I have an old Yoshimura catalog but it doesn't mention ratios. Nova gearbox ratios are different than yours. Who else offered one in the day, factory race kit? Quaife??
Some of the boys will know. How about a picture or two.  ;)
Offline cavebear
« Reply #3 on: June 11, 2010, 03:33:44 AM »
I'm going to count the teeth again to make sure I didn't make a stupid mistake.I am having trouble getting the second gear retainer clip off the main shaft, but i'll take what photos I can.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #4 on: June 11, 2010, 05:53:10 AM »
I have a Yosh CR box,but have to go to MBSC now(brother losing his battle w/cancer)when I get back can take pics and check gear ratios for you.I thought 1sr gear CR was = to stock 2nd gear ratio? Good luck,Bill
BentON Racing Website
BentON Racing Facebook
Offline cavebear
« Reply #5 on: June 11, 2010, 04:45:41 PM »
Thank you bill. Family first, toys second.
Offline City Boy
« Reply #6 on: July 07, 2010, 11:02:16 AM »
Hi.If your 1st gear on mainshaft is not integral with shaft,your trans is a genuine "970" unit.This is assuming,and I defer to others for this,that aftermarket close ratio units were not also like this.    Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline kos
    • m3racing.com
« Reply #7 on: July 08, 2010, 08:17:30 AM »
First gear on mainshaft is a one piece deal on CR750 kit box. I had three of them in last 30 years!
KOS
220...221, whatever it takes.
Offline cavebear
« Reply #8 on: July 13, 2010, 03:05:00 PM »
I had a chance to recheck the tooth count on the mainshaft gears and here are the corrected numbers
c1-47 teeth          1-18 t            1-2.60      1-24t             1-1.958
c2-41 t                2-24 t            2-1.70      2-27t             2-1.518
c3-36 t                3-27 t            3-1.30      3-30t             3-1.20
c4-34 t                4-31 t            4-1.10      4-30t             4-1.133
c5-31 t                5-33 t            5-0.94      5-34t             5-0.911
Bellcow, as you can see my first gear is the same as the stock second gear as you suggested.
city boy and kos,the 24 tooth first gear IS integral with the mainshaft.
Each side of second/third gear showing tool marks the other gears don't.
Offline kos
    • m3racing.com
Re: Yoshimura CR Trans ?
« Reply #9 on: July 14, 2010, 08:48:06 AM »
Thank you..I knew that... as I posted that comment.
KOS
    • BentON Racing
« Reply #10 on: July 15, 2010, 06:27:19 AM »
Good job Cavebear. I need to find mine and I'll check and get back.Thanks,Bill
Offline cavebear
« Reply #11 on: July 29, 2010, 04:57:10 PM »
SO, does anybody have or had a transmission with the same gear ratios as mine? Possibly a builders name? Thanks
