Author Topic: Starter Motor Rebuild - What to lubricate and what type of grease?  (Read 28428 times)
EverettShadowbrook
Hi All,
Rebuilding my lazy stater motor and I'm ready to reassemble. Just wondering what needs to be lubricated? Obviously the bearing, but what about the commutator / barrel piece where the brushes make contact? Should that also have a thin coating of some type of lubrication? Dielectric grease maybe?
Electronic parts scare me a bit just want to get it right the first time. Thanks for any feedback.
« Last Edit: June 07, 2010, 07:33:45 AM by EverettShadowbrook »
Offline Bodi
This area should be clean and dry. The brushes are compressed graphite, and will lubricate themselves and the commutator. If the brushes have gotten greasy somehow they are ruined, oil or grease turns the graphite dust into conductive tar that will basically short out adjacent commutator segments and reduce the starter's effectiveness.
You should clean out the gaps between the commutator copper segments with a stiff toothbrush and brake cleaner to get any carbon goo out. It it's really caked in then a metal tool can be used to scrape between segments. After that you will need to smooth off any ridges you created. This is simple, just cut a strip of 600 wet/dry and wrap it halfway around the commutator then turn the rotor to sand down the surface a bit while removing any high spots. Wash again with brake cleaner and dry, an air gun is good too to blast off any bits of sandpaper abrasive.
If you install new brushes it's a good idea to seat them before hard use. This involves running the motor for a half hour or so at reduced power (off the engine of course). A 2 or 5 amp battery charger should spin it OK. If the motor gets too hot to hold your hand on it stop and let it cool.
EverettShadowbrook
Good info. Thanks
Offline Frankenkit
  • Industrial Strength
I used a touch of light oil on the bearings (just enough to make them shiny, from a q-tip) but yeah, nothing on the brushes at all.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
EverettShadowbrook
Thanks for your help Guys and Girls. Successful rebuild of the starter motor. Working like new! Actually a very easy job.  ;D
