Author Topic: Will a 550 Motor bolt into a 750 Frame  (Read 2061 times)
Offline kj 47
« on: June 06, 2010, 08:30:54 PM »
I have a 550 will the motor bolt into a 750 frame?? I found a rigid 750 frame for cheap can I bolt my motor into it???? Thanks in advance
Re: Will a 550 Motor bolt into a 750 Frame
« Reply #1 on: June 06, 2010, 10:08:06 PM »
Measure and see.. if it has the right front to rear lower mount spacing , it will be easy..
Offline kj 47
« Reply #2 on: June 06, 2010, 10:53:22 PM »
Okay, ill ask the guy selling it to measure the mounts thanks for your advice.
Offline Flying J
« Reply #3 on: June 06, 2010, 11:02:08 PM »
Im pretty sure the answer is no it will not bolt right in. But it will fit in the frame, so you can modify it to bolt in. Easier then trying to fit a 750 in a 550 frame.
