Author Topic: Unifilter carb settings/Best place to get parts in canada  (Read 924 times)
Offline madness69
« on: June 07, 2010, 02:48:02 PM »
   Hello. nice site and forums. I just got myself a 73 cb500-4. It has old K&N filters on it so I decided to replace them with unifilters pods from dennis kirk. the carbs still run 100 main jets. I've read on these forums that its suggested that u go up to a 110 main jet. I guess what im asking is if someone who has used unifilter pods on there 500-4 could tell me what main jet and what they set there needle at. I know that I will have to do some tweeking, im just looking for a good starting point. I also read about "plug chopping"???? But I dont know what that is. I would also like to rebuild the clutch. I was wondering If anyone knows a good place to get part in Canada. I don't mind ordering stuff from the US but the shipping/tax/duty can get expensive. Thank you
Offline Bodi
Re: Unifilter carb settings/Best place to get parts in canada
« Reply #1 on: June 07, 2010, 07:01:39 PM »
There are many threads here about carb tuning. A plug chop is simple, it means, while riding, chopping the power (hit the kill switch and pull in the clutch) while running the engine at the performance point you're trying to tune and then coasting to a stop and removing one or more plugs for inspection. The plug colour and condition will tell you if the engine is running lean or rich (withing a pretty broad range). For carb tuning after engine, exhaust, or intake mods you start with wide open throttle at mid to high rpm and get the main jet size correct. Then you move down the throttle range and get the needle position (and taper if you have an assortment of needles or are willing and able to modify yours), slide cutout (if you have an assortment of slides or are willing and able to modify yours) and pilot jet/metering screw settings correct.
Modern practice is to do this on a dynamometer with exhaust gas monitoring, you can get much more precise measurement of mixture this way. It's an expensive process particularly with carburetors... with modern fuel injection you adjust the fuel map with a computer and changes are immediate rather than pulling the carbs, changing something, reinstalling them, checking the result ... and repeating many many times while paying a bunch of $$$ per hour for the dynamometer.
