Author Topic: CB750 Piston Ring Installation: Did I Do This Right?  (Read 2753 times)
Offline heyjones
« on: June 09, 2010, 10:08:04 AM »
I sat down last night and installed the piston rings on my new 2 over (.50) pistons that I got from K1. Just wanted to make sure I have them rotated correctly before I squeeze them in. I did my best to illustrate what I've got...
1976 CB750K
My Build Thread
Offline Bodi
Re: CB750 Piston Ring Installation: Did I Do This Right?
« Reply #1 on: June 09, 2010, 10:19:52 AM »
No two ring gaps should be at the same angle, and no gap should be at right angles to the piston pin (your 12:00 and 6:00). The actual angles are not important, you can have gaps aligned with the piston pins. I would st the top ring at around 2:00, scraper ring around 10:00, and the two straight oil rings at 5:00 and 8:00. with the spacer corrugated ring around 3:00 or 9:00. No rhyme or reason really, but it avoids gap alignment and the 6:00 and 12:00 positions. I've seen solid oil rings that look flat and some with slight bevels. The bevels if there should both scrape towards the corrugated ring, ie "sharp" edges towards the centre.
Offline heyjones
« Reply #2 on: June 09, 2010, 10:50:26 AM »
Thanks for the info, how does this look?
1976 CB750K
My Build Thread
