Poll
why didnt the kick work without the battery?
im i a dummy?
5 (62.5%)
alternator??
3 (37.5%)
Total Members Voted: 8
Author Topic: barebone wiring cb550--kick start help...one more question  (Read 6948 times)
spiderdan1331
« on: June 09, 2010, 08:20:22 PM »
ok...before i tore all the wires out to start from fresh, i tried kick starting it with no battery. didn't fire up. hardly cranked at all.
with the battery in i can use the kick start no problem...first kick, every time. runs great!
isnt there a way to eliminate the battery completely? is there maybe some sort of alteration needed to the alternator or ???
Offline CBGhia
Re: barebone wiring cb550--kick start help...one more question
« Reply #1 on: June 09, 2010, 08:33:25 PM »
The 550 will not work without a battery.  You need a charge to tell the stator what polarity to have.  You can get away with a small battery,  several people have used very small 12v batteries and put them under the seat hump on cafes
spiderdan1331
« Reply #2 on: June 10, 2010, 03:23:01 AM »
thank u for clearing that up...im gonna stick with a regular battery anyways
Offline cgancos
    • Flickr Page
« Reply #3 on: June 10, 2010, 05:36:26 AM »
If I'm not mistaken, a smaller bike such as a CB350 can swap over to a magento system and run the bike without a battery, but the 550 is eligible for this upgrade. It did make me a little sad when I found this out.
Offline Bodi
« Reply #4 on: June 10, 2010, 06:31:49 AM »
Any of these bikes can use magneto ignition  if you want to use 1920's technology in a 1970's machine, but you still need an alternator or generator to provide lighting power on a street bike. I think you mean using a permanent magnet alternator/generator which can work without a battery. It is possible to modify any SOHC4 to have a permanent magnet alternator but the job is never easy. Possibly the 350/400 has a crank end taper that fits another bike's permanent magnet rotor (CB77?) directly where the other models require more improvisation and machine shop work to do it. I don't know, I never had a huge problem with the stock system. You can use a small sealed battery if you lose the electric starter, the weight loss would be comparable.
redbullssg
« Reply #5 on: June 27, 2010, 12:19:43 PM »
I don't mean to sound stupid, but, So if you have a dead battery, then you can't kick start it?  What is the point of the kick start then?
Offline cameron
« Reply #6 on: June 27, 2010, 12:40:24 PM »
You can kick it if you don't have ENOUGH charge to actually run the starter motor.
1976 CB550F
