Author Topic: cycle x boxer build / 1st sohc build  (Read 14852 times)
Offline rippy154
Re: cycle x boxer build / 1st sohc build
« Reply #50 on: December 22, 2010, 02:47:26 PM »
Just Search Grimeca Rear master Cylinder, they come with lever up or down. You can make it but a bit of work..
 What are you using for axle nuts? If you thread each end to 3/4 NF ( I think) there is some cool axle nuts from Garner wescott.. top notch stuff.. tapered nut with an internal hex.. very clean looking.
 For the pipes try to tun em underneath, or build a gnarly high-pipe.. bit of work but looks cool and gives you ground clearance on a very low bike..
So I went here http://www.gardner-westcott.com/motorcycle_nuts.htm and didn't see the nuts you were talking about??? Do you have a link so I could see what you are talking about. I was just going to use acorn nuts but would like to see the ones your talking about first, My axle is already 3/4 NF I just have to cut it down and re thread on end.
Thanks for the tips I checked out the masters and the arm is interchangeable for pedal up or down and it is only $15. so i think I may order one just to play around and see what else I can come up with
Offline Tintop
« Reply #51 on: December 22, 2010, 03:33:52 PM »
Really like where your going with this build rippy 154.  Lots of nice details.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #52 on: December 22, 2010, 07:45:10 PM »
I just looked and could not find.. my second choice is the ALLEN NUTS, if you can get in 5/8 or 3/4 inch.
 I used to buy direct from G-W years ago , will see if I can dig up a part #, may have one in my shop somewhere, they were a tapered internal hex sprcial made chrome nut.
 Another thing, they have that is nice is hardened chrome washers.. and wrenches always fit their chromed stuff.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #53 on: December 23, 2010, 07:18:56 AM »
I can make you some fists that can cover up whatever nuts you use. Now THAT says chopper/boxer build!! BTW 3 wheeler fun time in the snow soon.
Offline rippy154
« Reply #54 on: April 29, 2011, 05:41:16 PM »
Sorry for no post in a long time I have several other projects going from home remodeling, to restoring a 53 ford f100 and a 69 chevelle and raising my 2 kids, but I forget where I have left off but I will throw up a few pictures so I can get your opinions because they always help with the direction I go in
Offline MasterChief750
  • Detonation
« Reply #55 on: April 29, 2011, 07:54:10 PM »
is that the cyclex sidewinder?
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Zaipai
    • My Home page
« Reply #56 on: April 29, 2011, 08:37:52 PM »
Awesome looking bike rippy, every thing seems spot on. I really love the stance. I can't wait to see what you do for the headlight etc..
Great work!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline rippy154
« Reply #57 on: April 30, 2011, 05:38:12 AM »
It is basically what cycle x sells as there super sidewinder, I had bought the vance and hines pro pipe from Tommy Summers awhile ago and the slip on part of the pipe was just to long and did not look right, I ended up buying the reverse cone from Cycle X. It is not  just a slip on though you need to do a little work to make it fit to the Vanes and hines pipe. If you are thinking of doing it I will take some photos of what you will have to do... plus you could check out this web site   if you had something else in mind
http://www.coneeng.com/pdf/Motorcycle%20Webpage%2011_1_10.pdf
Offline rippy154
« Reply #58 on: April 30, 2011, 05:50:30 AM »
Great work!
.: Scott :.
Funny you should ask about the headlight
So I couldn't figure out what i wanted to do with the headlight, I thought about fork tube mounts but I really think those are more Cafe style so I figured I would try to build something off the bottom tree. It started with a chunk of 3/4 pine and a cool 3/4 post I found on ebay.  I made a mock up and than had a guy at work take my scetch and turn it to a cad drawing and than sent it to buckhorn bully from cycle x and he was able to use his CNC mill to make the bracket for me
here is the wood template and post
here is the cad drawing
here is the CNC aluiminium bracket and the Diecast headlight I thought looked right on the bike
Offline Zaipai
    • My Home page
« Reply #59 on: April 30, 2011, 07:24:33 AM »
Absolutly perfect. You were correct, it does look better. Much better.
Tail light? ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
