Author Topic: Stuck kicker  (Read 1167 times)
Offline sparty
  • I just play one on TV
    • Gallery
Stuck kicker
« on: June 13, 2010, 12:24:26 pm »
What would cause the kick starter to freeze.  It won't budge.  1972 CB750
Sparty
1972 CB750 K2 Cafe' Style
Offline WFO
  • Will work for powerbands
Re: Stuck kicker
« Reply #1 on: June 13, 2010, 12:35:28 pm »
Have you verified that the engine it self is not stuck? a wrench on the flywheel side should eliminate that.
82 cb650 sc nighthawk - 78 kz 650 b
Offline sparty
    • Gallery
Re: Stuck kicker
« Reply #2 on: June 13, 2010, 12:37:47 pm »
No the bike runs fine, just the kicker that is the problem.
Offline WFO
Re: Stuck kicker
« Reply #3 on: June 13, 2010, 12:45:36 pm »
Sounds like your starter gears are buggered up somewhere i personally have never had this problem and would think opening the side of the motor is in order but hopefully somebody has ran into this problem before and can offer a less messy alternative. A look at an engine blow up may help narrow it down?
Offline WFO
Re: Stuck kicker
« Reply #4 on: June 13, 2010, 01:01:55 pm »
Just thinking maybe try putting it in fourth and roll it backwards a bit and see if it frees it up?
Offline sparty
    • Gallery
Re: Stuck kicker
« Reply #5 on: June 14, 2010, 12:39:52 pm »
yeah it is really strange.  I looked at an exploded view of the engine and can't figure out what could have hung up.  If the spring popped wouldn't it still turn but not kick over.  I am stumped.
Re: Stuck kicker
« Reply #6 on: June 14, 2010, 12:46:00 pm »
Hate to say it but besides being broke, its hard to fix. Nothing is accessible without removing the lower crankcase.
The only problem I've ever heard of is that the shaft iteself breaks and the starter goes limp. Enough of the shaft stays in place between bearings, that the oil pump gear remains perfectly fine.
I guess you could have broken a tooth and jammed it in.
Offline sparty
    • Gallery
Re: Stuck kicker
« Reply #7 on: June 14, 2010, 01:02:03 pm »
If a tooth broke and jammed wouldn't it freeze everything.  The bike runs fine.
Re: Stuck kicker
« Reply #8 on: June 14, 2010, 01:16:36 pm »
I've got to think about it a little, but there is a springloaded pawl mechanism that resides within a gear. When you press down on the kicker that engages the internal flange of the gear, turns the gear which turns the mainshaft I think. When the engine catches, the mainshaft turns the kickgear which disengages the pawls and lets everything spin. The kick gear is spinning the whole time, so it couldn't be a tooth, you're right. It must be in the pawl mechanism, that is, the pawls have broken or stopped working.
Never seen that happen before, its a pretty stout mechanism. Nevertheless, you're looking at an engine removal and teardown, at least the bottom end.
PS: I still don't think thats it. I'll have to look, I've got one apart.
PPS: Just looked at a fishy. Not much else it could be, but I can't see it.
« Last Edit: June 14, 2010, 01:21:51 pm by MCRider »
Offline sparty
    • Gallery
Re: Stuck kicker
« Reply #9 on: June 30, 2010, 08:41:21 am »
The kicker is no longer stuck.  I adjusted the clutch.  Put the bike in top gear, rolled it (more like pushed it), put it in neutral. What do you know the darn thing freed up and kicked over.  It is beyond me why it was hung up.  Maybe all the leg work at the gym finally payed off  ;D
Sparty
Re: Stuck kicker
« Reply #10 on: June 30, 2010, 09:34:57 am »
If you pressure wash it, and dont use the kicker, you could get corrosion right behind the seal in the clutch cover..
Offline sparty
    • Gallery
Re: Stuck kicker
« Reply #11 on: June 30, 2010, 07:10:58 pm »
754,
Never been pressure washed.  In fact the bike is basically new since the total rebuild.
In fact it has never been washed.  I wipe it down after every ride.  Good therapy to spend some time cleaning and polishing the bike - it is a thing of beauty.  I admire it every day and I still think it is the prettiest bike I have ever owned.  Something special about these CB750s.
