Author Topic: How long for RedKote to fully cure?  (Read 1513 times)
Offline Scott S
« on: June 13, 2010, 03:25:16 PM »
 I used RedKote on my '71 CB500 tank last Wednesday. I followed the instructions carefully. I did not dilute the RedKote with acetone or MEK. The tank was clean and dry before starting.
 I drained the tank the best I could and sat it on a wooden frame I had in my garage. For the first few hours, I would go out and gently roll the tank some more and tilt it so that anything left in there would go towards the petcock hole. It drained on it's on, with the gas cap open, since then.
 The "backbone" and walls if the tank have a nice, thin coating that is dry and hard to the touch. Along the bottom of the tank and in the seams, it is thicker and looks like the coating on a candy apple. I can stick a long screw driver in there and touch it (gently) and it sorta feels rubbery. Or at least not rock hard.
 I can still smell that "solvent" smell. The instructions stated that it's fully cured when the smell is gone. It's been four full days. Think it's gonna be OK or did I screw up somehow?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline fmctm1sw
Re: How long for RedKote to fully cure?
« Reply #1 on: June 13, 2010, 04:26:39 PM »
I did mine with a POR 15 kit and I think I did it on a Sunday and didn't ride until the next weekend.  I'd give it another day and see what happens..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Hondell
  • Just an easy 1000 Hr. resto
« Reply #2 on: June 15, 2010, 11:50:10 AM »
Mine was taking a long time so I stuck my compressor hose in the filler hole and jammed the valve to allow a trickle of air for a couple of days and that did the trick.
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline Lenny55
« Reply #3 on: June 15, 2010, 02:13:10 PM »
I let my tank sit for a week and I could still faintly smell the solvent smell before I put it back on the bike.  The shop recommended letting it sit until the Monday (had it done on a Friday), but I let it sit a few days longer because I also read that it was fully cured when the smell was gone.  Finally I couldn't wait any longer.
Anyway, I haven't had any problems with the lining and it's been about a month.  FWIW.
Lenny.
'73 CB500
