Author Topic: Harbor Freight O rings???  (Read 7076 times)
Offline Elniniomuchachos
« on: June 13, 2010, 10:08:27 PM »
Any body ever use the Harbor Freight O Ring kits on their bikes?
If so how was the quality?
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
Re: Harbor Freight O rings???
« Reply #1 on: June 14, 2010, 02:46:25 AM »
I haven't used any of them on my bike yet but I have used them on my truck without any issue. It wasn't on the motor but on the connections for my transmission cooler which gets fairly warm.
Offline kerryb
  • Not a very
« Reply #2 on: June 14, 2010, 04:21:17 AM »
I took two matching o-rings from a harbor freight assortment box , put one in gasoline, the other on the table.  At the end of the day, the one in the fuel had swelled noticeably.  You might get away with it, but I don't think o-rings in the carb are supposed to do that.
Offline jamesb
« Reply #3 on: June 14, 2010, 04:30:45 AM »
my friend uses them all the time in his auto repair shop so far he hasn't had any issues with them.
Offline Inigo Montoya
« Reply #4 on: June 14, 2010, 08:51:08 AM »
There are o-rings and then fuel resistant o-rings. o-rings used in refrigeration are usually sufficient for fuel applications.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: June 15, 2010, 04:44:11 AM »
Harbor Freight sells both viton and nitrile o-rings.  Make sure you know what you're buying.
mystic_1
- John Augustus Shedd
co425
« Reply #6 on: June 15, 2010, 05:20:01 AM »
mystic_1
+1.
I would just get your o rings in the size you need from mcmaster carr. Quality parts decent price and material selection. I have noticed that HF o rings have casting marks on them that others dont. I would not use them for high heat, fuel or internal engine. That prety much rules out the cb750 right there.
Offline Raef
« Reply #7 on: June 15, 2010, 05:32:43 AM »
I have a set of both the metric and standard HF o-rings, I have used them for many things from vibration damping to the seals on my main jets. on an occasion that one would swell hampering reassembly I would just replace it.
they are cheap and yes they do have a mold ring around the outside. I usually use 1 size smaller putting a slight stretch on them
Mark
Offline mrrch
« Reply #8 on: June 15, 2010, 07:08:14 AM »
Watch out, the metric kit i got online was the same as the standard set but it was labeled with the metric equivalent (that made it metric/ go figure)
Useful once in awhile, the Japanese generally use thinner orings on most things.
my build
Offline magconpres
« Reply #9 on: June 18, 2010, 04:06:36 PM »
I put one of these around the oil orifice that fits in the top of the cyl block (CB400F).
It is the Nitrile variety.
Should I be concerned about it's ability to take the heat?
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
