Author Topic: Front Brake caliper  (Read 797 times)
Offline Otto
Front Brake caliper
« on: June 14, 2010, 05:37:20 AM »
Hi All,
I am in the process of putting my 71-CB750K1 back together... I am working on the caliper. I'd like to disassemble it and make sure it is working ok, before putting it back together... I have done quite a few old Honda's but never been successful at removing the pad. piston side to figure out od they were ok or not. Seems the one I have alwsy stick.
How do I take this thing apart? Check it?
Thanks-
Bob
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline HondanutRider
Re: Front Brake caliper
« Reply #1 on: June 14, 2010, 06:22:45 AM »
Your best bet would be to pump the entire piston out, pushing out the pad at the same time - especially if the pad is stuck.  You will want to get everything cleaned-up and the pad needs to slide freely for the brake to work well/properly.
Keeping the caliper connected to the brake lines, but disconnected and the other half apart,  pump the brake lever to cause the piston to extract and push the pad out.  This will get messy as the piston gets ejected and the brake fluid dribbles out.  However, getting the piston out is a good thing to be able to check it and the seal for damage and most important to clean everything up very well.
Another way to extract the piston and push the pad out, is to take the caliper apart and off the lines.  Then you can try attaching an air compressor line to the hydraulic inlet to "pop" the piston out with air pressure.  This can be dangerous as you have to wrap the parts being ejected in a rag and watch where you point the thing as it could fly out with some force (and also spray fluid).  Maybe safer would be to use a grease gun and pump out the piston with grease.  (Then you really need to clean the insides.)
Clean and make sure everything is spotless.  Use brake cleaner fluid.  Make sure the piston bore and the piston and particularly the seal groove is spotless.  Clean off the brake pad and its housing chamber.  Removing rust and crud with fine emery would be OK for the pad and its housing, but be careful on the piston and its cylinder - it should retain a mirror finish so use a scotch pad or something soft to scrub there if required.  Use lots of brake cleaner fluid.
Reassembly of the clean and dry parts needs proper lubrication - and different lubricant for the different parts:
1.  The piston is inserted with only clean, new brake fluid.  Everything below the o-ring seal in the cylinder should be lubed ONLY with brake fluid.  Push the piston into the cylinder until it bottoms out.
2.  Smear a small film of dielectric grease around the top of the protruding or now flush end of the piston, along the rim where it meets the cylinder.  Work some of this grease down into the walls of the cylinder around the top wall of the piston.  (There isn't much of any clearance for anything here, but whatt you want to do is get a seal that moisture and air can't penetrate.)
3.  There likely is a washer of nylon that sits on top of the piston, between it and the pad backing - "glue" that on with a bit of high-temp silicone.
4.  Coat the back of the brake pad backing and the housing for it in the caliper, with a "sparing" amount of anti-seize compound - not too much, just enough to "paint" the surfaces.  (You don't want excessive compound to dribble out onto the brake pad surface - its supposed to not be slippery.)
5.  Re-assemble the caliper onto the fork, placing the inner pad into its housing after applying a dab of high-temp silicone to its backing.  (The silicone theoretically will help to stick the pads to their respective parts of the housing and piston, so that they move as one, as well as providing some damping quality to eliminate vibration and squeal.)
6.  Presumably (and ideally) the brake system will have been completely drained, so top it up with fresh, new fluid.  DOT4 is now recommended, but the original spec of DOT3 is also good.  Just don't mix the two - use exclusively one or the other.
7.  Make certain that the pivot hinge is clean and lubricated.  Also adjust the hinge pivot screw once the pads have been set.  Pump and purge the entire system of air.  These procedures and re-doing the master cylinder is covered elsewhere in this forum, and should also be addressed if you are already doing the above for the caliper and pads.
That's my experience and summary of research for what is required.  Others may have different opinion from their own experiences, but this is what I've found to work very well for me.
« Last Edit: June 14, 2010, 06:29:14 AM by HondanutRider »
Offline nippon
    • Classic Cycle City
« Reply #2 on: June 14, 2010, 06:33:23 AM »
Thigten the bleeder screw, put the whole caliber in a towel blow with air compressor into the whole where the metal hoses is going in.
Make sure, that the piston will be shot in the towel,.....the piston is coming out with high speed, so do not fright.
nippon
« Last Edit: June 14, 2010, 07:23:26 AM by nippon »
Offline Otto
« Reply #3 on: June 14, 2010, 07:06:38 AM »
Thanks!
I'll give those all a try.
Bob
Otto
Offline justind511
« Reply #4 on: June 14, 2010, 03:26:05 PM »
ok i just had the same problem on saturday with my 74cb550 front caliper. compressed air everything nothing worked. the best thing to do is get a grease gun that will fit onto your bleeder valve and find a bolt with the correct size and thread where the brake line goes and plug it, a little grease may come out the threads but thats ok. as you pump the grease in make sure you push down on the end that is on the bleeder valve and you will see the pistoon come out. go to www.oldmanhonda.com and there is a great description on how to clean it up and out and reuse the old oring. i used 2 small screw drivers that came with stihl chainsaws to clean out the groove. i grinded one down to a small flat thin point to get the oring out without messing it up. then i heated and bent the second screwdriver and grinded the sides down a bit to fit in the groove perfectly and scraped out all the junk in the groove. carb cleaner will help alot in this proces. good luck let me know if this helped! it worked great for me! some grease guns can put out 5000 ps1. they use grease guns to tighten tracks on construction equipment because of the high psi
1974 cb550K
