Author Topic: Master Cylinder - Do I Need This?  (Read 566 times)
Offline Johnie
« on: June 14, 2010, 11:34:32 AM »
Under the master cylinder cap there is a plastic washer of sorts the same size as the cap. Must be to hold the master rubber in place when tightening it. Is this a necessary piece? The reason I ask is my KO & K4 came without it. The K1 had it in place. Needed or not needed??? Thanks
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Inigo Montoya
Re: Master Cylinder - Do I Need This?
« Reply #1 on: June 14, 2010, 11:36:55 AM »
I have it on my 77 and it IS needed to keep the rubber from deforming when you tighten the cap. Without this, it will leak.
Offline Johnie
« Reply #2 on: June 14, 2010, 11:43:35 AM »
I wonder why the PO took them off? It is not like they fall out. The K1 I actually had to screw it past the threads. Guess it is order time...
Oshkosh, WI  USA
« Reply #3 on: June 14, 2010, 12:06:10 PM »
I had to get a new one when the original cracked. Even with a crack it leaked.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #4 on: June 14, 2010, 07:10:00 PM »
I have one on my K3 - just looked. Never knew it was there till now!
