Author Topic: New Wheel Bearing Spin  (Read 1266 times)
Offline quidger
« on: June 14, 2010, 04:23:13 PM »
I put new wheel bearing (OEM from Honda) in the rear wheel of my CB550. They installed fine and I'm sure that I did everything right. I also re-laced with new spokes. I put the wheel on the swing arm to true the wheel and the wheel spins but not as freely as I think that it should. Should the wheel spin very freely with almost no drag since I put in the new bearings. If it should spin with virtually no drag I must have some type of issue. But looking at the installation of the bearings it looks fine. Could the axle spacer be binding on the bearings?
Thanks for any ideas.
Re: New Wheel Bearing Spin
« Reply #1 on: June 14, 2010, 04:58:24 PM »
YOu haven't tightened the axle up yet?
I'll be interested in what others say.
Offline quidger
« Reply #2 on: June 14, 2010, 05:26:36 PM »
I tightened it up, not real tight. Should the axle be tightened down all the way? I thought for truing the wheel I could just snug it down.
« Reply #3 on: June 14, 2010, 05:45:56 PM »
For truing, just snug is fine.  Ultimately of course it must be tight, probalby 50-75Ft lbs torque. But frankly I don't know after all these years exactly how it should spin, unencumbered by the brakes and chain. I'm guessing a firm spin should get 2 revolutions, but I'd like to hear from others.
Offline quidger
« Reply #4 on: June 14, 2010, 07:30:47 PM »
I'd guess that is about what I was getting on a firm spin - 2 to 3 revolution. I was expecting it to spin much more. Maybe that's normal. Maybe someone else will chime in.
« Reply #5 on: June 15, 2010, 03:27:32 AM »
theyre not like a bicycle which will spin forever,2/3 or 4 revolutions.
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #6 on: June 15, 2010, 06:33:52 AM »
May I ask why decided to change them in the first place?
