Author Topic: My 82 CM450E almost done  (Read 1659 times)
Offline hyredgunn
« on: June 15, 2010, 07:25:33 PM »
You say it cant be one, I say move over #$%*
Offline Alan F.
Re: My 82 CM450E almost done
« Reply #1 on: June 16, 2010, 12:02:40 PM »
nice job, how's it ride?
Offline Uncle Ernie
« Reply #2 on: June 16, 2010, 01:33:11 PM »
OH?  there's a CM450 in there?
YOW
So that seat's about 6 inches off the ground?  ???   :D
Did you do all that plumbing?  How did you know what size pipe to use?
What's the front end from?  Totally custom one-off seat?
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #3 on: June 16, 2010, 06:38:45 PM »
can't wait to show my friend. he's got a cm450 and a couple of 400 "parts bikes."
nicely done!
1974 CB550K
                                  Your 1%er name
Offline hyredgunn
« Reply #4 on: June 25, 2010, 11:21:40 AM »
The little bike rides real nice, one thing i cant believe is how much power it has, crazy for a 450cc
Ok a quick run down on what was done, I cut and stretched the swing arm 6'', the frame cut and hard tailed. The seat frame started out life as a rear grab bar off this bike, the seat it self is aluminum base that i built and had a friend cover, the air bag is from a project for a customer that never got finished. The rear fender used to be the front, the fender struts, I made my self. The front end is stock with a 1.5'' spacer in the fork tube to get a little lift and stiffen up the ride a bit. all of the work was done by me on a weekend, except for the seat cover. Oh ya, the paint is translucent blue from Checker auto parts, nothing like a good coat of commander crylon lol.
Offline Alan F.
« Reply #5 on: June 25, 2010, 07:16:25 PM »
Nice.   I'm wondering about your exhaust, are those hollowed out stock mufflers attached directly to the downpipes?
How loud is that?
-Alan
Offline hyredgunn
« Reply #6 on: July 05, 2010, 08:05:09 PM »
How loud is that?
-Alan
Yes the pips are gutted and mounted to the head pipes, Its loud enough to make people wounder what it is.
Offline Alan F.
« Reply #7 on: July 06, 2010, 09:10:49 AM »
Cool.  When I get to building mine I'll probably do the same except for gutting the mufflers.  I'm thinking of fabbing up a crossover pipe too, any thoughts on that?
Offline hyredgunn
« Reply #8 on: July 19, 2010, 02:30:54 PM »
Ya a cross over pipe will change the sound a bit and maybe help on the low end
Offline Alan F.
« Reply #9 on: July 19, 2010, 04:27:51 PM »
Thanks HG!  I'm thinking of making up some aluminum drag pipes for the right hand side of the bike, I've got some length of aluminum tubing that are about 1-1/2" ID with a 2 or 3mm wall thickness, I can make up some couplings on my little lathe and braze the sections together with HTS-2000. A crossover pipe shouldn't be very hard to achieve.  I'll likely make up a few different types of baffles to try, and right now I'm thinking of staggered slash cut ends.... I've got a build thread on another forum, I should start one here and fill in the blanks.
-Alan
Offline Alan F.
« Reply #10 on: July 20, 2010, 06:35:41 PM »
Scratch that idea, I doubt I can get two pipes past this style brake pedal and have it look right.
Slash cut pipes on both sides, maybe I've got something I can make a pair of mufflers out of.....
I wonder how much lighter than stock it'll be....
