Author Topic: Air filter preference?  (Read 2837 times)
Offline Scott S
« on: June 16, 2010, 12:32:38 PM »
 '71 CB500
 What's your preferred air filter for the stock air box and why?
 K&N (I've had good luck with these over the years but pricey )
 Uni-Filter (looks like a less expensive alternative to the K&N but I don't have much experience with them)
 Stock replacement (semi affordable, but genuine Honda or aftermarket? And where do you get yours?)
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Air filter preference?
« Reply #1 on: June 16, 2010, 01:45:09 PM »
K&N lokks cheaper and cheaper considering they last for a loooong time.
Offline Frankenkit
  • Industrial Strength
« Reply #2 on: June 16, 2010, 01:52:16 PM »
I noticed a power difference putting the K&N on the cb650... when I finally need one on the Chevy, I'm getting a K&N for it, too.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Inigo Montoya
« Reply #3 on: June 16, 2010, 02:02:01 PM »
K7N. The honda filter is not cheap for a 750. The after markets are not always that good.
« Reply #4 on: June 16, 2010, 02:21:22 PM »
'71 CB500
Where did you find a K&N for the stock air filter box on the CB500?  I thought they had discontinued them.
I use the Uni NU-4055 filter, and have for about 15-20 years.  I like that it is reusable.  And this makes it the most economical.  The foam is kind of a statistical filter rather than the stock absolute type.  So, if you are operating in really dusty environments, the stock filter can save your rings and cylinder walls.  But, the stock filter always needed replacement on a yearly basis, due to the paper filter fibers sagging and getting ever more restrictive, as well as trapping some particles that can never be cleaned out of it.
On average, I get better gas mileage overall with the UNI filters. As they have slightly less pressure drop across the membrane and this remains so between cleanings.
In my experience, of course.
Offline Scott S
« Reply #5 on: June 16, 2010, 02:24:31 PM »
 Well, I see them listed on ebay. I haven't tried to order one yet, though.
'71 CB500 K0
'81 Yamaha XS650
Offline westondc
  • Wes Mantooth
« Reply #6 on: June 16, 2010, 02:34:55 PM »
'71 CB500
+1, i replaced my stock filter on my '72 CB500 with a UNI last summer and i have no complaints. bought mine from Rusty Riders. remeber, if you go Uni you'll have to buy the filter oil and cleaner http://cgi.ebay.com/ebaymotors/Uni-HP-Air-Filter-Honda-CB500-CB550-CB-500-550-Four-F-_W0QQcmdZViewItemQQhashZitem53e0c80706QQitemZ360253490950QQptZMotorcyclesQ5fPartsQ5fAccessories
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline Scott S
« Reply #7 on: June 16, 2010, 02:41:31 PM »
 I have a K&N cleaner/oiler kit. Is there any reason I couldn't use the K&N oil on the Uni filter?
'71 CB500 K0
'81 Yamaha XS650
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #8 on: June 16, 2010, 03:36:42 PM »
Naaah...Go ahead and use it, it will be fine.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline westondc
  • Wes Mantooth
« Reply #9 on: June 16, 2010, 03:43:58 PM »
um.... i'm not sure about that. i was wondering the same thing so i posted on the forum about it a while back. i was told that K&N oil is different because the K&N filter isnt foam like the Uni filter. I also checked the K&N oil and it stated "do not use on foam filters"
1972 Honda CB500k1
1971 Honda CB350k3
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #10 on: June 16, 2010, 04:19:43 PM »
When I went to the motorcycle dealer the guy told me you can use basically any oil on the uni. He said everyone used 2 stroke oil back in the day.
I bought a uni last summer, used k&n oil and have not had a problem. 2k miles and 10 months so far.
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
« Reply #11 on: June 16, 2010, 06:09:18 PM »
I guess I don't understand the reluctance to follow manufacturer instructions.
The dealer is a salesmen. His goal is to move money from your pocket to his.  Many of them will say anything to induce that transfer and move product off their shelves.  Their liabilty for product application pretty much ends when you walk out the door.
Oil, as almost everyone knows, is a descriptor that applies to many formulations.  There are also many foam formulations, too.  Some more resistance to certain chemicals than others.  I would think the manufacturer would know what oil formulation is compatible/beneficial for their product, much better than the dealer or internet speculation, anyway.
The risk is that the substitute oil you choose for UNI foam may cause it to break down faster, or it may simply not help it maintain it's integrity like the recommended oil does.  Of course, the foam may also be indifferent to the chemical you experiment upon it.
I don't know if K&N oil is good, bad, or indifferent to the UNI foam composition.  I do know that my first UNI filter lasted 15 years using UNI's filter maintenance kit.
When I got a K&N filter for the 750's, I also bought the K&N filter maintenance kit.  So, I have both UNI and K&N product and I use the correct kit for the filter to be maintained.  Neither kit lists the exact chemical content of their kit.  Nor do the filters come with a list of chemicals with which they can co-exist.
If you use products on them outside of their recommendations, you can't expect the manufacturer to back the product, or for the product to meet manufacturer claims.
Offline westondc
  • Wes Mantooth
« Reply #12 on: June 16, 2010, 07:14:56 PM »
Very well put TT.
1972 Honda CB500k1
1971 Honda CB350k3
Offline patricke9
  • SOHC4 #2037
« Reply #13 on: June 16, 2010, 08:41:11 PM »
Do all 500/550's F's & K's all use the same filter?
"I did everything by the seat of my pants. That's why I got hurt so much."
Evel Knievel
1978 Kawasaki KZ650
« Reply #14 on: June 16, 2010, 09:26:11 PM »
Mostly.  The 500 doesn't have the engine breather element with the big stand pipe like the 550's.  The Uni NU-4055 adapts to both.  I think the stock paper types are different between 500/550 models.  I don't know about what Honda offers today for the 500.
All the 550s F or K used the same filter element in stock form.
Offline patricke9
  • SOHC4 #2037
« Reply #15 on: June 16, 2010, 09:36:38 PM »
thanks, been doing some searching of part #'s and of course the one for my '77 k model is discontinued, been able to find a few for the '77 F model, I think you sold me on the Uni filter, 15 years is of use is worth the extra $$.
Evel Knievel
1978 Kawasaki KZ650
« Reply #16 on: June 17, 2010, 01:15:22 AM »
i pulled one apart(heat the glue with a soft flame) then put it back together with two pack locktite glue,im using three layers of "finer filter"foam soaked with motul filter oil.
« Last Edit: June 17, 2010, 01:17:18 AM by dave500 »
