Author Topic: Rusty gas tank fix through the miracle of electrolisys!  (Read 3805 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« on: June 16, 2010, 03:08:01 PM »
This is from a pay forum, but the thread is open. The OP converts rust in his Chinese copy DKW looking bike.
Enjoy!
http://forums.somethingawful.com/showthread.php?threadid=3307016
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline gnarlycharlie4u
  • Far from being an
Re: Rusty gas tank fix through the miracle of electrolisys!
« Reply #1 on: June 24, 2010, 11:24:04 AM »
DUDE!!!
do you have stairs in your house?
It'd be nice if I wasn't the only goon on here.
Offline PanAmerican
« Reply #2 on: June 24, 2010, 12:53:08 PM »
This electrolisys method works very well.  I've used it with excellent results.  You can buy the sodium carbonate at any pool supply store.  It's commonly referred to as PH Up or PH Increaser. (Don't get it confused with sodium bicarbonate, which is just ordinary baking soda.)  A short piece of steel rebar can be used as the annode. All you need is a battery charger, some charging cables and you're set to go.  Make sure to get the polarity right.  It really does makes rust magically disappear.
« Last Edit: June 24, 2010, 01:03:34 PM by PanAmerican »
redbullssg
« Reply #3 on: June 27, 2010, 11:11:55 AM »
IDK, I used some Simple Green to rinse the tank out, then bought some AirConditioner Cleaner and some baking soda to neutralize the AC cleaner.  I just put about a quart of the AC cleaner in and closed the cap, sloshed it around every now and then, while I was tearing down the bike.  Before I poured out the AC cleaner, I mixed up a 5 gallon bucket of warm water and the soda.  You will need the whole 5 gallons.  Then with the soda water handy, I funneled the AC cleaner back into the bottle to reuse later, then immediately poored the soda water in.  It will start to foam as it reacts with the AC cleaner, thus why you will need the whole 5 gallons.  Just keep pouring it in slowly until just water comes out, then cap and let set for an hour or so.  Times up, poor 2/3 of the soda water out, then slosh it around and poor the rest out.  Follow this up with some WD40 or Marvles to keep it from rusting again if you plan on shelving it for a while, or just put it back on the bike and fill it with gas....  I will take pictures of the difference, and it doesn't look like that tank on the inside.  It looks like brand new.  I have two tanks, both were in then same condition on the inside, well the blue one was a little worse, as it was left open for some time.....
« Last Edit: June 27, 2010, 11:26:38 AM by redbullssg »
