Author Topic: quick carb need question for a cb350f  (Read 564 times)
Offline jamesv220820
« on: June 18, 2010, 01:14:31 PM »
replacing the needles in the carbs and the needles have 5 different places where the small clip can go , how do i know where to put the clip?
thanks
james
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline Gordon
  • 750K1, 550K2
Re: quick carb need question for a cb350f
« Reply #1 on: June 18, 2010, 01:23:31 PM »
Make note of where they were before you remove them from the original needles. ;) ;D
Joking aside, there is rarely a need to replace any of the brass parts in the carbs as they don't typically wear out, and aftermarket needles have been known to have a slightly different shape/taper than stock Honda needles, which can make for subtle but annoying changes in how the bike runs.
« Reply #2 on: June 18, 2010, 01:29:03 PM »
ya i think the previous owner replace the needles before and the clips look like they are all over the place some closer to the bottom some closer to the top , especially looking down the carbs intake the tube surrounding the needles some are higher up some are more closed/lower ,  i didn't wanna change the needles but with the throttle climbing i'm doing a whole overhaul on these carbs ,
so should i put all the clips in the middle?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: June 18, 2010, 01:38:08 PM »
Unfortunately I don't know the stock setting for the needle clip on the 350, but I'm sure someone who does will be along soon.
As for what you see when looking through the carb intake, if you're saying the slides (metal cylinders) are all uneven, then that's a synchronization issue, but if it's the needles that look uneven when compared to the even slides then there's definitely a needle setting problem.
Offline Triffecpa
« Reply #4 on: June 18, 2010, 02:07:37 PM »
the middle position is always stock.
Tracy
