Author Topic: Some ding dong pumped my caliper shut while the weel was off...help?  (Read 1346 times)
Offline ironbutter
  • 1971 CB750 K1 ~ JDM ~ Polynesian Blue ~ 8K mi
Apparently forgot I, errr he had taken the wheel off. Obviously the caliper pinched shut as he pumped all that fluid. What is the best way to set the puck back to allow me to put the wheel and brand new Dunlop tire back on? by relieving the bleeder valve? Thanks!
« Last Edit: June 19, 2010, 09:22:02 PM by ironbutter »
"Most motorcycle problems are caused by the nut that connects the handlebars to the saddle."
Offline scunny
  • don't call me expert
Re: Some ding dong pumped my caliper shut while the weel was off...help?
« Reply #1 on: June 18, 2010, 09:21:50 PM »
that's what I would do
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
scrapvalue
« Reply #2 on: June 18, 2010, 09:23:39 PM »
Open the bleeder valve and carefully pry the brakes open with a screw driver.
Should open up easily.
« Reply #3 on: June 18, 2010, 09:58:38 PM »
Next time stick a pce of cardboard folded a few times in there, or a pce of plywood..
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #4 on: June 18, 2010, 10:27:29 PM »
Who was the ding-dong??
I like berries.
Offline ironbutter
« Reply #5 on: June 18, 2010, 10:51:02 PM »
Um... well, ok. I was concentrating on the electrical connectors in that damn bucket. Haha.
« Reply #6 on: June 18, 2010, 10:57:15 PM »
Yeah, likely story. I have never had that experience. (Yeah, right, maybe 5 times? ;D)
« Reply #7 on: June 19, 2010, 04:42:39 AM »
You could take out the two allen bolts and split it in half and use a c clamp to compress it back. If it was me and it had not been done in awhile I would pull the pad and piston and give it a good cleaning while your down there  ;)
Offline Alan F.
« Reply #8 on: June 19, 2010, 07:06:37 AM »
One easy way way to avoid this issue is to simply remove the brake lever first every time the front wheel comes off.
This way nobody can squeeze the lever.
-Alan
co425
« Reply #9 on: June 19, 2010, 08:11:34 AM »
What I do is zip tie a wood block between the brake lever and the grip. Then no dummie i.e. me can grab a handfull of front brake.
Offline ironbutter
« Reply #10 on: June 19, 2010, 09:21:50 PM »
yup, just removed the caliper bolts and pulled the caliper apart and used a c-clamp to clamp it back into position, went for a nice ride on my new dunlops, sweet.
« Last Edit: June 20, 2010, 10:17:00 AM by ironbutter »
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #11 on: June 20, 2010, 09:59:04 AM »
cut the ding dong's fingers off as a lesson to others. can't let this stuff slide.
Offline Alan F.
« Reply #12 on: June 20, 2010, 11:49:41 AM »
Sweet indeed!
Offline ironbutter
« Reply #13 on: June 20, 2010, 12:57:14 PM »
Thanks for the help all...perfect morning for a ride, I really like the Dunlops...
« Last Edit: June 21, 2010, 06:59:46 AM by ironbutter »
