Author Topic: Slow build.... 78' 750f2  (Read 2366 times)
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« on: June 18, 2010, 09:26:35 PM »
So here it is ... my first post of my 2nd riding project... not much for writing so I'll just throw some pics at you. Right after purchase 3 yrs ago i got clip-ons, dunstall replica seat, led light, headlight bracket.... got her running and rode it for the summer.
Offline eosmontana
  • 71k2, 78f2
    • SubM2
Re: Slow build.... 78' 750f2
« Reply #1 on: June 18, 2010, 09:41:03 PM »
here is how she sits now after lots of cleaning, some speed holes, home made exhaust, filled emblems, electronic ignition, new coils, lowered the forks through the trees 1.5" (quicker steering andfeels like a much smaller bike this way), Home made side cover, pod filters, jets and new tires, chain and sprockets.
« Last Edit: June 18, 2010, 09:44:31 PM by eosmontana »
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #2 on: June 18, 2010, 09:43:27 PM »
and here are some parts i've been collecting / working on for the next phase. No where near some of the builds on here... but i like what i've got going so far... and I'm having a sh*t load of fun riding it.
« Last Edit: June 18, 2010, 09:51:16 PM by eosmontana »
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #3 on: October 09, 2012, 05:11:11 PM »
well... only been 2 years and i finally decided to redo the CB.
Got a new frame and started making some modifications i.e. fitting seat, cutting tabs etc. Thats when i noticed the PO had hacked off the kickstand leaving a large gash in the frame....
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #4 on: October 09, 2012, 05:12:44 PM »
fixed the kickstand and welded the frame then proceeded with some rearset mounts.
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #5 on: October 09, 2012, 05:15:06 PM »
a little teardown action... notice the gobs of gasket sealer smeared on the valve cover courtesy of ..... you guessed it ..PO
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #6 on: October 09, 2012, 05:26:24 PM »
finally to pull the engine... I was alone and didn't want to tip the bike for fear of damaging the engine so i came up with this.... Removed all bolts and mounting bits and anything that will hold it up. Left 2 bottom bolts in. Took a foldable ladder in a scaffolding shape and put a 2x4 across the rungs through the frame where the carbs would be. I then used 2 ratchet straps and looped them from the 2x4 to the engine around the alternator and timing bumps. Then I ratcheted up the engine alternating sides and proceeded to CAREFULLY walk the bike out to the side. It took a lot of wiggling  because i left the exhaust studs on, but all in all it was fairly easy. As I walked the bike out i kept a milk crate next to the frame in case the engine fell and to set it on when done. Worked pretty well....
