Author Topic: CAM CHAIN Removal Question??  (Read 703 times)
Offline sniper1
  • SNIPER1
« on: June 19, 2010, 07:45:35 AM »
'77 CB550K. I am about to replace the cylinder head gaskets. I have the rocker cover off, exhaust off, carbs off. I am trying to get the cam chain off the sprocket and am having no luck. It is way too tight. I am kinda confused on the cam chain tensioner, I loosen the nut, turn the screw to the right (clockwise) (90degrees) retighten nut, and still can't get the chain off the sprocket. I removed the two bolts on the sprocket and slid to the left just like the manual says.
Does anyone have any suggestions???? I don't want to break anything, but need to get the chain off the sprocket.
Offline Patrick
Re: CAM CHAIN Removal Question??
« Reply #1 on: June 19, 2010, 07:51:43 AM »
Remove the cam chain tensioner from the engine. It's just three bolts and pulls right out, That should give you the slack you need to remove the chain, If it doesn't then you chain is probably binding. Rattle it and move it backward and forward a bit to loosen it up.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 19, 2010, 08:08:17 AM »
When it's time to put it back together take a look here:
http://forums.sohc4.net/index.php?topic=369.msg57914#msg57914
