Author Topic: cb360 horn......  (Read 2016 times)
Offline weltzing
cb360 horn......
« on: June 19, 2010, 03:59:41 PM »
the horn doesnt work, i check the wires there are two going to the horn, a light green and a black. the black has continous power to it and the green doesnt have any....im wondering what it should be???
Offline KB02
Re: cb360 horn......
« Reply #1 on: June 20, 2010, 04:40:56 AM »
Check the black against the ground. You should have nothing. When you hit the horn button, though, it should ground out.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline kirkn
« Reply #2 on: June 20, 2010, 04:41:42 AM »
The black supplies power to the horn, the light green is the ground wire that goes to the push button.  When you push the horn button, you're completing the ground circuit, and that's likely where the problem lies - in a corroded push button.
However, to verify the horn itself, hook a test wire up to the terminal where the ligh green wire connects and touch it to a good ground, like a clean unpainted spot on the motor.  With the key on, that should beep the horn.  Then you know the problem is in the button.
Or, you may have both - a corroded button AND a horn that doesn't work.  Many times the horns will corrode up inside and you can free 'em up by lightly tapping the sides with a screwdriver handle and/or working the litte tone adjuster screw on the back in and out a few times and/or energizing them to free 'em up and get 'em working.
Good luck with it.
BTW, have you checked out the HondaTwins site?  It's a bit more 'twins' focused than the 'Other Bikes' section of this 'fours' site.  :)     http://www.hondatwins.net/forum/
Offline weltzing
« Reply #3 on: June 23, 2010, 11:49:07 AM »
it was in fact a bad horn, bought a new one hooked it up and HONK!!
