Author Topic: im getting in to my K8.. what should i do?  (Read 689 times)
Offline the technological J
  • deliciouso!
« on: June 19, 2010, 11:26:15 PM »
so im gonna be changing my head gasket and polishing the crap outta everything..... from pistons to ports to covers... so what would u do thats fairly cheap that you wish you would have done when u were into your engine.... im hoping to do this once and only once...... so any help could be appreicated this isnt mhy first time into an engine just this one... but i know that theres always something that i wish that i would have done different..so im trying not to learn the hard way
EDIT: heres my build thread also
http://forums.sohc4.net/index.php?topic=60257.0
« Last Edit: June 19, 2010, 11:28:57 PM by thegabrielj »
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline KB02
Re: im getting in to my K8.. what should i do?
« Reply #1 on: June 20, 2010, 05:01:05 AM »
If you are taking off the head, do yourself a favor and go a step further and pull the jugs as well and replace the base gasket. All too often when taking off the head, the base gasket will unseal and then will never seal correctly again when you torque everything back down causing a slow weep of oil at the base of the jugs. Also, while you have the jugs off, you can check them out and make sure that everything is in speck with no wear or anything, hone the cylinders just to glaze bust them, and then you're good to go.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #2 on: June 20, 2010, 08:42:41 AM »
I had this happen to me when I redid my leaky head gasket. It's only a little extra effort, and it is worth it. Also, make sure you get the complete gasket kit with all the little o-rings and rubber discs. Replace them ALL. When you yank the head, don't forget to clean and flush the oil jets that feed the top end. THIS IS VERY IMPORTANT IF YOU LOVE YOUR CAM!!!
And lastly, ignore the "Kate Haters" that lurk on this board. Why people waste hate on the later model years that could be better spent on Harley's I'll never understand.
Make that thing into what YOU want and the hell with external opinion. It's YOUR bike, not their's!
Gonzo out.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
  • deliciouso!
« Reply #3 on: June 20, 2010, 10:36:06 AM »
I didnt realize they had a word for it "Kate Hate"  I m trying to get my hand on a 74 also i dont know why but the oler the better to me
i have a gasket set ordered and am planning on having it bead blasted..... i might just soda blast it if its all the same....has anyone painted thier block black and then taken off paint on the very end of the fins like you see on some night versions of engines....
 im thinking about some pods.... any body have some and really regret it? is it only asthetic or if i port the heads will it help the performance? i was just thinking of going up 2 sizes on the jets
94 ST1100..Gone
Offline Alan F.
« Reply #4 on: June 20, 2010, 11:46:59 AM »
Use genuine honda valve seals.
  • deliciouso!
« Reply #5 on: June 20, 2010, 01:41:01 PM »
i got my gasket set from cyclex
94 ST1100..Gone
