Author Topic: 550 bobber attempt  (Read 15707 times)
Offline COMB2
Re: 550 bobber attempt
« Reply #50 on: February 02, 2011, 04:01:52 AM »
I used the stock arm and chopped the top off. Had an old bike and chopped off the pedal crank. Weld them together and smooth out a bit. Went to the local bike shop got a pedal to screw into the crank I weldded on. I ended up using just the center part of the pedal. I took off the grippy part of the pedal and wrapped a piece of flat stock to go along with the theme
Offline MoMo
  • Ride like you're invisible
« Reply #51 on: February 02, 2011, 04:25:29 AM »
Good luck trying to tune that bike with those pipes and also get used to shorter valve life, no back pressure is not a good thing..
Plus........Don't know where you live but around PA it is also illegal...Larry
Offline fastbroshi
  • Puppet
« Reply #52 on: February 02, 2011, 04:18:40 PM »
  Have you been inside the carbs yet?  Those jets shown on DCC aren't correct for your carbs.
Just call me Timmaaaaay!!!
Offline COMB2
« Reply #53 on: February 02, 2011, 06:12:38 PM »
Humm I asked in a post here and that's where I was pointed too. Unless I miss understud
Offline COMB2
« Reply #54 on: February 02, 2011, 06:15:37 PM »
Btw why they wrong?
Offline Raef
« Reply #55 on: February 02, 2011, 07:42:52 PM »
I don't know the part #'s and those may just be stock photos, but the jets in the photos are not jets for those years of cb 550 carbs.
The main jets are press in with a o-ring and slows are very long, they screw in and have a long skinny tube on one end
Mark
Offline Raef
« Reply #56 on: February 02, 2011, 07:43:22 PM »
btw i dig the build ;D
Offline COMB2
« Reply #57 on: February 27, 2011, 12:00:30 PM »
Yep the jets were wrong. Guy at the local shop dug thru a couble sets of old carbs and found some bigger ones.
Anyway just rode it for the first time yesterday. Pipes aren't very loud.
<object width="480" height="390"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="390"></embed></object>
Offline COMB2
« Reply #58 on: February 27, 2011, 12:01:35 PM »
not sure why there is 2 vids but they are the same thing ???
Offline cdoggy81
« Reply #59 on: February 27, 2011, 05:37:39 PM »
Very cool ride!
