Author Topic: Dealing with the 500/550 "flat spot".  (Read 1567 times)
« on: February 09, 2006, 12:39:20 PM »
If you've ridden lots of other bikes, you've probably noticed a "flat spot" between about 3500-4800 RPM on the "mid-four". This is caused by several factors, all relating to certain things Honda wanted this bike to do:
1.) It was supposed to idle well and start very easily. This requiired an idle A/F mixture of about 14.25:1, a little rich.
2.) It was supposed to be quiet. Long intake runners (distance between the carb slide and intake valve) helped this.
3.) It was supposed to be easy to maintain and not leak fuel, so that carbs were to sit horizontally.
4.) It was supposed to be even and smooth through the whole throttle range.
5.) It was supposed to cruise easily at highway speeds 55-75MPH and get good MPG.
It did all these things, and very well. But, the tradeoffs of design caused by the long intake runners (#2) and the angled direction change into the heads (#3) made #4 and #5 harder to obtain. The richer idle had to lean out at running speeds to get good MPG. To smooth all of these things out a little, the spark advance curve was made quick, quicker than the other fours of the day. The result: between 3500-4800 RPM (or so), the mixture was slipping from richer-than-normal to normal while the spark advancer had already reached full timing. It made the torque curve flatten out in that range, where most bikes are just getting stronger.
Here's some simple things you can try to smooth over this "smoothie" feature.
A.) Raise the jet needle in the carb slides one notch. Install a 10-size smaller main jet at the same time (5 size smaller on last-year CB550). Switch from the standard D7E (NGK) or X22E (ND) sparkplugs to the D8E (X24E) at this same time. Check the color of your plugs to make sure it does not get too lean, which can happen if you've installed indivdual air filters and/or headers that actually work (most did not), or longer, megaphone-type mufflers.
B.) Advance the timing 2 degrees static, but cut off one turn from the springs on the advancer and reshape the end of the next coil so the springs will fit back onto the advancer mounts. This slows the advance curve about 5%-8%, depending on the year of your bike.
C.) Add 4 teeth to the rear sprocket. This raises the RPM a little, which shifts the lower-than-normal torque curve downward a little to a point where the torque-vs-acceleration is not so noticeable.
D.) Test out your octane ratings. Start with a tank of Regular, then try Mid-Grade, then premium. You'll see how they affect this "flat spot".
Here's some harder things you can do to smooth this anomaly while increasing the power a little:
E.) Smooth the insides of the intake runners and match the ports.
F.) Polish the intake valves.
G.) Shorten the intake valve guide bosses about 2-4mm. Narrow them in the flow direction, but don't get thinner than 50% of the original thickness.
H.) Change from the stock air filter (paper) to a K&N filter. Open up the airbox intake holes about 25%.
I.) Install a cam with 7 degrees more duration and advance it 3-4 degrees. Action Fours used to make one of these in the early 1970s.
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: Dealing with the 500/550 "flat spot".
« Reply #1 on: February 09, 2006, 01:30:03 PM »
Quick question relating to opening up the airbox:
You've reccomended this on nearly all of your mods, whether they be for the 750 or 500/550.  I've heard an old trick on some cars was to cut or drill holes in the airbox above the filter.  Would this work on these engines?  It would be easy to "Swiss cheese" the airbox cover and it may help flow.
« Reply #2 on: February 09, 2006, 06:52:19 PM »
The easiest way is to notch the inside of the openings. The air dam that blocks most of the sound makes a chute of sorts, up the side of the box. Cutting the inside away improves the flow almost 25%. It does make the carb noise louder, so you can add a baffle inside the box, right up against the side of the filter, to block the direct path of the noise. The filter is very large, compared to the volume passed, so this little obstruction will have no negative effect.
There are 2 inlets on the CB750 box, one front and one rear. With some work, these can also be widened across the faces of the box, using stainless steel sheet and some 4-40 screws. It beats the racket from using individual air socks (which drives me crazy when riding all day). I've forgotten how the 500 box looks: it's been almost 15 years since I worked on a 500!
Most of my "recommendations" are coming from my note collections of the days when I had those bikes, or worked on them for a living.
Offline MrZxp
« Reply #3 on: February 09, 2006, 09:36:11 PM »
Well, many thanks HondaMan.... when I first purchased my 550 all those years ago it drove me crazy to have that flat spot at around (an indicated) 3350 rpm - as I recall I tried all sorts of "cures" (can't remember specifically right now!), all to no avail.... eventually gave up and put it down to one of the quirks of the machine.... when I'm finished with the 750, I'm gonna check out some of your recommendations!!  :)
Phil
09 Boulevard M90
SOHC4 Member #3336
