Author Topic: Getting closer...CB750A supercharged-fuel injected  (Read 21946 times)
Offline 23tbucket
« on: June 20, 2010, 10:47:07 AM »
I thought some might like pictures before the bike gets taken apart for final welding, painting and plating?
Some of you may be intersted in the supercharger set-up? It's an "Aisen" AMR500. The blower pumps 500cc of air per revolution. I'm running 1:1 ratio (crankshaft speed) which should give me around 6psi boost? This blower is found on many smaller Japanese cars not available in America. This one came from a 600cc engine. I bought it through "Japan-auction"..similar to our "Ebay."
I used a little  external alternator to keep up with the added electronic fuel injection load so I took the blower drive off of the the engines alternator end. I went with 1"wide timing belts. First drive is from the old alternator rotor up to a jackshaft. This jackshaft is adjustable for belt tensioning. From the jackshaft their is a double sided belt which is tensioned with the little alternator.
The air is pulled from the bottom of the blower. Not the best to be pulling in warm air, but....!!Their is a little flat filter on the intake.  These blowers will work in CW or CCW rotation. Here's a couple of plenum pictures.
Some might be interested in the fuel injection end of things. The throttle bodies are from a Suzuki GSXR600. "Microsquirt" is going to control things. The "oil tank" you see is acctually a second gas tank that holds the Suzuki fuel pump.
I'm going to "try!" COP (coil on spark plug) on this build. The "Microsquirt has 2 built-in ignition drivers,but a lot of extra #$%* is required to fire 4 separate coils. From talking with Gary with "Power-Arc" I should be able to use the system from Ken with "Cycle-ex". By keeping the ignition wiring away from the ECM I shouldn't have any generated "noise", which can be a real problem in the tight confinds of a motorcycle. The coils are commonly used on larger displacement Fords. They are 1.5 ohms.
The oil cooler set-up is derived from different Honds!. I can't remember what and where!!LOL
Their is a #$%*load of wiring, relays, etc, on this build. I need a big wiring box. The access covers are from a CX500.
I won't bore you with the frame stuff (you've seen one, you've seen them all!) I will show you my set-up for controling the rear drum brake with hydraulics. This would work fine for someone with disabilities? I'm using a Harley clutch master cylinder on the handlebars to activate a "pull" type of hydraulic cylinder.
I hope some here can use some of my ideas or at least get some inspiration. Please feel free to comment or ask questions. Take care; Clifford
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
Re: Getting closer...CB750A supercharged-fuel injected
« Reply #1 on: June 20, 2010, 11:38:34 AM »
Wowzers, this is nuts! Can you post up some video when you get this beast running? It's an automatic too? I'd almsot kill for that motor in my bike, sans the auto tranny. Great stuff!
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline lordmember1969
« Reply #2 on: June 20, 2010, 12:36:39 PM »
Nice:) Let me know how the EFI turns out:) Are using the gsxr throttle boddies and microsquirt for my build. But have not come to the weiring yet.. Have you had it running?
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #3 on: June 20, 2010, 04:11:23 PM »
What mods did you do to the GSXR TB's to make them fit?
Offline Ricky_Racer
« Reply #4 on: June 20, 2010, 07:00:18 PM »
Very impressive engineering and workmanship. Thanks for sharing!!!  :o   RR
Offline Bamboozler
« Reply #5 on: June 20, 2010, 08:22:40 PM »
Sweet mother of fab, awesome job on what you’ve done so far Clifford!  Can’t wait to see it finished up, thanks for sharing!
'78 CB750F Turbo, 101 rwhp @ 8 PSI (Project thread)
2007 Yamaha FZ1
'78 CB750F basket case crying for a resto
'78 XL250S
'78 Suk GS750E
Digital Ignition project (Project thread)
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #6 on: June 20, 2010, 08:45:10 PM »
 :) slicker than owl #$%*....and THATS slick    ! 8) 8) 8) 8) 8)
I like berries.
« Reply #7 on: June 20, 2010, 09:11:28 PM »
Life is so unfair, I can't access those pics because of the defence department's firewall blocking pic hosting sites, but I'm gonna go home early and check 'em out on my home computer, this bike's description sounds awesome! Cheers, Terry. ;D
« Reply #8 on: June 20, 2010, 09:24:11 PM »
Way cool!! Keep us posted, especially about your experiences with the microsquirt.
« Reply #9 on: June 21, 2010, 01:43:26 AM »
I raced home to check out the pics, and I'm not disappointed, what a beast! I'd love to see the looks on the pilots of modern sports bikes when you light the wick on that thing! Beautiful engineering too mate, well done! ;D
traveler
« Reply #10 on: June 21, 2010, 03:58:41 AM »
Very cool!
Where is your oil tank??
~Joe
Offline 23tbucket
« Reply #11 on: June 23, 2010, 11:16:43 AM »
Thanks for the comments guys, blokes, and mates!! he! HE!
Rickmoore: You bet, I will do a video...might even put an old tire in the rear and melt her down!!!(burn-out)
Lordmember: Hey, I'm also Norski! My grandparents immigrated to Canada in the 1940's. Still got lots of relatives up in the northern part eg; Bardu. Good luck with your Fuely as well.
Retro Rocket: I'll see if this link works? A "how too" on starts second page about 15th post?
http://hondachopper.yuku.com/topic/24588?page=1
Traveler: The automatics didn't have separate oil tanks...just a bigger oil pan and the torque convertor itself holds a lot of oil.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #12 on: June 23, 2010, 11:25:55 AM »
verry interesting. those auto 750's are intriguing.
can't wait to see how this turns out.  8)
1974 CB550K
                                  Your 1%er name
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« Reply #13 on: June 23, 2010, 11:27:48 AM »
jee-zuss...
I think I just pee'd a little...
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #14 on: June 23, 2010, 05:10:57 PM »
Can't wait for that burnout, the poor tire doesn't know whats coming....  ;D
1995 EG6
Offline mgbgt89
« Reply #15 on: June 23, 2010, 05:25:11 PM »
SWEET JESUS! Man that thing is awesome. What kind of wheels are those? Are you a fabricator by trade, because that is some beautiful work!
Offline 23tbucket
« Reply #16 on: June 23, 2010, 06:04:21 PM »
Thanks mgbg: The wheels are off a 1983 Honda CB750SC. Sandblasted and black wrinkle powdercoated them. I'm a Heavy Duty Mechanic and Millwright, in addition to being addicted to any old 4 cylinder Honda!
Offline HedNut
  • Underwater Basket Weaving
« Reply #17 on: June 23, 2010, 07:33:13 PM »
CRAZY WICKED BUILD!!! There's some magical stuff happening on this bike....
CHEERS!
traveler
« Reply #18 on: June 23, 2010, 08:47:29 PM »
Good thing you will be staying at 6 Psi boost.  Without an intercooler, you would have to run race gas or retarded timing with any more boost!  The EFI is what's going to make it really work well.  I have an injected and supercharged mustang...they work well together!
~Joe
Offline octalz
  • I know.... cute.
« Reply #19 on: June 23, 2010, 09:09:42 PM »
WOW!
Are you at all concerned about the clutches or torque converter holding up? Why did Honda detune the 750A with smaller carbs and milder cam?
Again, WOW!
« Reply #20 on: July 09, 2010, 06:10:03 AM »
Can not wait to see how it turns out:) How is the coil in plug coming along..? Will wait to see how it turns out and then steal your ideas :) Bardu is about 1300 miles up north from where i live:) Very similar nature to some parts of Canada I have heard :) Thanks for the links regarding the Microsquirt:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #21 on: July 09, 2010, 06:48:38 AM »
Wow this is an amazing build! Thanks for sharing! I see a definite BOTM here...
Is it running yet?
cheers
Andy
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #22 on: July 09, 2010, 07:53:15 AM »
SWEET SWEET build!  can't wait to see how it turns out!  that bike is CRAMMED full of go-fast goodies!!!
with that tiny coffin tank, and what's behind a twist of the throttle, what do you think you'll get, 1, maybe 2 gas stations to the mile??   ;D ;D ;D
Offline 23tbucket
« Reply #23 on: July 09, 2010, 09:52:38 PM »
Thanks again, fellows. Bikes all apart now. All the tabs and brackets have been welded. I just got to clean up a couple of welds, get the frame sandblasted, drill a few holes for wiring, then off to the powdercoaters. I sent the stuff out today that gets the chrome treatment....yeh!, I know...chrome don't get you home!!!!LOL. Acctually this is the first bike I've built that I am getting anything chromed! A lot of the stuff on my other bikes that came chrome were sandblasted and powdercoated. A bit of chrome looks good...a lot of chrome ...not my style.
Octalz: Apparently the torque convertor in the SOHC 750 is the same as the Honda Civic. If the convertor can last in a car at 4 or 5 times the wieght, it should last in a motorcycle? I believe a lot of drag racers were using the 750 Automatics back "in the days." I'm not sure why the Automatics were de-tuned.....maybe for smoother idling due to the torque convertor holding thing? They also have less of a compression ratio than standard clutch and gear models.....perfect for "huffing!"
Wannabridin: The prism tank holds about 2 1/2 gallons and the auxillary tank (with the fuel pump) holds another gallon. The "miles per gallon" or "kilometers per liter" (or is it kilometers per 100 liters?) will depend on how I set-up the fuel to air mixture. If I set it close to stoicometric, it will most definatly go further than a similar carburated engine, but will be lacking the engines full potential. A small  high reving 750cc likes to be on the "rich" side for starting and idling, but pulls the most power at higher RPM''s and a bit on the lean side.....PS...I hate LEAN.....tends to ruin engines!!!LOL
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #24 on: July 09, 2010, 10:06:15 PM »
 :o :o I love this one! Hope to see it running soon!!
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
